Pignose work .. schematic ?
Started by petemoore, July 04, 2008, 08:27:19 PM
  I got a Pignose 'donated' for 4th of July !
  Haven't checked, but I bet the speaker works.
  Opening it revealed bug-circuits in spiders web [both battery packs and the board were dangling from the remaining intact wires.
  And the board says '6800' and also 'creation' is written on it.
  A sticker says 'made in Hong Kong'.
  That leaves at least 4 wires N/C. and there's a wiring harness.
  Another neat surprize is that there are two 'large for pignose' transformers on the PCB with the 2 output transistor looking IC's and a couple...other transistors.
  The outer hardware has a rust-patina, the nose-knob is missing...otherwise with a little bit of patience it looks like I could try out the transformer laden PCB for sound...has anyone seen a schematic for something like this ?
B Tremblay
Pete, email me through the 'groove address and I'll send the schematic to you.
B Tremblay
runoffgroove.com
#2
  Thanks B.
  Appreciate it !
  I tried the 'contact@runoffgroove.com' adress, hotmail, says it's unable to send to that adress through.
  I'll try again later.
