LM386 Equivalents?
Started by CodeMonk, July 08, 2008, 12:31:10 AM
CodeMonk
Topic says it all.
I'm building another headphone amplifier. The LM386 works wonder for this.
Any Ideas?
dxm1
Are you having trouble getting LM386s where you're at, or just wanting to try something different?
You could do one with op amps, e.g:
http://www.headwize.com/projects/opamp_prj.htm
or totally discrete:
http://www.electronics-lab.com/projects/audio/018/
(don't forget to cover those nekkid component legs with tape or shrink wrap to be _totally_ discrete...)   ;D
CodeMonk
No, I can get them at RatShack. Just that I need to build a headphone amp tonight and don't have one.
But I have tons of circuit boards with loads of various chips on them.
I do really like the way the 386 works, nice little chip.
I did just spend a little bit of time on http://www.datasheetarchive.com looking for similar items.
Thanks for the links
ambulancevoice
nope, the 386 is a unique ic
i think its the only ic avalible today with variable gain
there are other amplifier ics but they usually require different circuits/requirements
LM380 (requires a heat sink and is a 14 pin dip puts out 3 watts max i think)
NJM2073 (is a stereo amplifier ic, about same wattage as lm386 8 pin dip)
there is also this
http://www.diystompboxes.com/analogalchemy/sch/headamp.html
uses (very) common transistors, no ic
Minion
The LM386 is a Pretty Noisy IC for a headphone amp , I have used them and while they work they are definately not "Hi-Fi" ...You could build a Headphone amp like the CMOY with a Regular Fet opamp useing a curcuit that is not much more complex than the LM386 curcuit and with better noise specs and less Battery consumption....
CMOY
http://headwize.com/projects/showfile.php?file=cmoy2_prj.htm
Cheers
Go to bed with itchy Bum , wake up with stinky finger !!
CodeMonk
I like the 386 design I am using, not noisy at all. I've had good luck with it so far.
A very simple design.
But I will look into that CMOY idea...looks intriging.
Thanks to all
