Hot Resistor in a Budget EH Bass balls
Started by anticpunk, July 19, 2008, 07:00:49 PM
anticpunk
Hey,
I just bought another Bassballs pedal from ebay (to mod) and when I plug it in, the first resistor in the V+ line heats to the point of a smell. I replaced it thinking maybe I just had a fluke resistor problem, but even the replacement gets hot. I replaced the electrolytics in the supply thinking maybe I had a shorted cap. No dice. There are no shorted traces and the polarity is correct at the board.
Also I should mention that I am getting no audio out. Not sure where to go with this issue. Maybe the 4558 is shot? Guesses?
Thanks!,
Jay
theehman
Ron Neely II
fx schematics and repairs
anticpunk
No. Just the first resistor (either a 47 ohm or a 470 ohm, don't recall currently). I cant locate a short anywhere on the traces so i'm guessing its a component issue someplace.
Thanks,
Jay
anticpunk
upon closer inspection, I found a little odd blob of solder that was shorting + to - on the first Cap in the V+ line. Problem solved. Works great now.
Thanks,
Jay
