Help with R.G's math
Started by JOHNO, July 20, 2008, 12:19:25 AM
JOHNO
Over at geo in the technology of the fuzz face R.G explains how to measure the gain of GE transistors. Do i just set my DMM to DC voltage as if i was checking voltages at a transistor in circuit or measuring a battery? The math he uses confuses me for example (4ua)*(100)*(2472)=0.9888V How does that work? And another (100E-6)*2472=247mV. Any one know what goes on here?
mac
Quote(4ua)*(100)*(2472)=0.9888V
4ua = 4 micro ampere = 0.000004 amp = 4E-6 amp = 4/1000000 amp
0.000004 amp * 100 * 2472 Ohm = 09888 Volt
Quote(100E-6)*2472=247mV
100E-6 = 1E+2 * 1E-6 = 1E-4 = 0.0001
0.0001 amp * 2472 Ohm = 247mV = 247 milliVolt = 247E-3 Volt = 0.247V
:D
mac
JOHNO
#2
Thanks mac. It seems I may not have explained myself properly. What im after is how to do the sum. You know, how do i put those numbers in my calculator and get the answers that RG gets?
EDIT: Oh now i see it (i think). I was never any good with math spent too much time dreaming about the young lady sitting next to me. Thanks again Mac.
mac
I posted the math behind RG test because you may need to know the gain of your transistors under different base currents, that is, gain is a function of the current going into the transistor:
http://www.diystompboxes.com/smfforum/index.php?topic=45481.0
If you are familiar with Excel you can use the equations to get gain and leakage.
QuoteI was never any good with math spent too much time dreaming about the young lady sitting next to me.
I know exactly what you mean, that´s why I´m 42 and single :D :D
mac
JOHNO
What does the "E" represent? And why does 100E-6=1E+2*1E-6? I still haven't got a grasp on that yet.
Roobin
E means "x10 to the power of the number after" so 100E-6 is 100 (x 10^-6), and 0.1E2 (or can be written as 0.1E+2) is 0.1 (x10^2).
100E-6=1E+2*1E-6? Think of it as (1E+2) x (1E-6). That should make it clearer.
StephenGiles
mac
