R.G Keen single pot vibe LFO question
Started by ohmelter, July 22, 2008, 09:12:48 PM
ohmelter
Hello. I've modified my vibe to a single pot speed control. However, I have a few "bugs" I'm not sure how to remedy. I'm using the VTL5C3/2 and have a 560 ohm resistor for Re. The speed is still not able to go "as-fast-as" it was with the dual pot. Problem is, the lower I go in ohm's on Re, I get way too much gain on the volume after the LFO...to the point it overdrives. There's some stuff i need to change. Just don't know what.
Anthony
You're fighting the nature of the LDR. LDRs don't go all the way to 0 ohms. Pots (in theory, sometimes in practice) do. Highest speed is with lowest resistance. Lower the 4.7K resistors in series with the "pot".
ohmelter
Thanks R.G. I'll try that out and report back.
Anthony
ohmelter
That did the trick!! I lowered the two 4.7k resistors to 2.2k, and it speed things up.
Thanks,
Anthony
