eq "shelving"
Started by km-r, July 23, 2008, 11:33:01 PM
km-r
hi!
i wanted to know how to create a shelving eq, i think thats what its called.
you see a friend of mine wanted to recreate the freq response of his cranked up tube amp so we fx-looped a graphic eq after the preamp.
the result is a flat freq in the bass and a increased/"shelved" response of about 10db at about 2khz flat to 20khz.
i wanted a cheaper and discrete circuit that resembles this freq response. certainly not a high pass filter because it will suck out plenty of bass.
thanks in advance!
Look at it this way- everyone rags on air guitar here because everyone can play guitar.  If we were on a lawn mower forum, air guitar would be okay and they would ridicule air mowing.
zyxwyvu
Try paralleling a 220k resistor and a 680p capacitor before a 100k resistor to ground.
Change the capacitor to change the frequency, and the resistors to change the attenuation at low frequencies.
If you want a boost instead of just attenuation, you can add a simple amplifier to this circuit.
Here's a picture to show the circuit and frequency response.
Ben N
You'd have to calculate the values, but I have the impression (from O'Connor's book, maybe?) that a cathode bypass cap in a tube amp creates a shelving response. That may be where it comes from in your friends amp (could also be the speaker). If so, the same thing ought to work in a SS single stage as well, using the emitter or source bypass cap. Not sure if you have to scale values, though, but try something like a simple NPN boost with the same cap value as on the amp's input stage on the emitter?
Hopefully someone a little smarter can chime in on this.
stm
km-r, do you have access to a 2N5457 FET?  If so I can provide you a suitable circuit.
jayp5150
Quote from: zyxwyvu on July 24, 2008, 05:37:58 AM
What program is that? I was just thinking about trying to find something like that earlier today.
zyxwyvu
Quote from: jayp5150 on July 24, 2008, 06:41:13 PM
It's called Simetrix. I use the trial version that you can download for free here: http://www.catena.uk.com/
The trial just has a circuit size limit (that's pretty big), so it works fine for just about any stompbox circuit.
jayp5150
Quote from: zyxwyvu on July 24, 2008, 07:06:44 PM
Cool, thanks. I'll check that out.
flo
km-r
thanks for the help guys,
i just downloaded Simetrix software demo... this will be great! you can actually simulate circuits' frequency response here?
zyxwyvu
Quote from: km-r on July 27, 2008, 12:01:16 AM
Yes, just put in an AC source, connect it to the input, then put a voltage probe on the output of the circuit. Go to Simulator->Choose Analysis... , and check AC, and run the simulation.
rogeryu_ph
Hi Km-r,
Welcome me back   :D, I'm still eyeing on our project for insanity box just give me some times.
well i get suck with GT forum for a while. Is the eq your using was a ten band unit co'z it has more bass reponse isn't it. Well it also depend on Amp send/return direct mix level, some high-end amp provide or design control for this, most of these are solid state amp but I know some modern tube amp nowadays has too.
Roger
