little dpdt question
Started by snufkin, July 26, 2008, 01:31:01 PM
snufkin
hi i use 3pdt all the time but im building this
im using up old parts someone gave me
and i have an old school x wing dpdt
im a little stumped on how to orientate the x wing so it matches the diagram of the dpdt  (is it even that simple)
easyface,phase 90,many fuzz faces,feedback looper,tremulus lune and so on soon to be ADA!
snufkin
like  one of these
i guess i just need to find out what lugs connect on a normal non stomp dpdt switch and then what the equivalents are on an x wing stomp switch
brother numsi
orientate it with two rows of three, either way works.
made sense?
snufkin
that does make sense but
if you look here there is only one way it can be orientated like that and thats how i have it wired now (as the diagram above shows)
and thats not right as the lugs are not connected in the same way as a dpdt like this (or so i suspect )
thanks
brother numsi
O | O
O | O
O | O
O    O
O---O
O    O
Boogdish
If you want to make sure for yourself, get a multimeter and check continuity between lugs when the switch is in either position.
