Tremulus Lune - Build Report and Troubleshooting
Started by studiostud, July 29, 2008, 04:55:15 PM
studiostud
Here's another question regarding the LED then... how would I wire it to a 3PDT if I wanted just to scrap the on/off LED?  and then also, would it work to wire two LEDs to the same spot on the 3PDT so one is turned on from the source power and the other pulses from the "board power".
Builds Completed: Big Muff. Fuzz Face. Tube Screamer. Rat. Crash Sync. Harmonic Jerkulator. 6-band EQ. Rebote 2.5. Tremulus Lune. Small Stone. Small Clone. Microamp. LPB-2. Green Ringer. Red Ranger. Orange Squeezer. SansAmp. MXR Headphone Amp. Bass Fuzz.
frokost
This wiring method, found from the FAQ, works best with what you want to achieve: http://www.diystompboxes.com/pedals/images/3PDTwiring.jpg
Now, instead of running a wire from +9V, take the top wire from the Tonepad layout there. Omit the resistor, connect the cathode of the LED to the bottom LED pad on your board, not to ground.
