real mctube squealing
Started by luke691, July 30, 2008, 08:14:48 PM
luke691
i recently finished the real mctube circuit from tonepad and prior to having put it in an enclosure (hooked up with jumper leads it was working fine, now when i turn the gain control too far i get a high pitched squeal. all cable is shielded except for power cables and the heaters. any suggestions as to what is wrong??
luke691
woops, i should ad that it only occurs when capacitor 7 is connected, when it is disconnected the problem is not present
