Need help fixing an EX-1 Expression Pedal
Started by Mr.Durden, August 01, 2008, 01:42:34 PM
Mr.Durden
I bought my DL4 when they where inlcuding free EX-1s with purchase and ever since i got it the sweep sucked and it would wig out on me after a while of use; i would set the toe position at the value i wanted, and after like 4 sweeps the value would automatically reduce, i tried it on both a DL4 and an FM4.
Anyway, i opened it up and everything is in order (not like theres allot to the pedal) so i suppose its a faulty pot. The line 6 website says these use 10K pots, this one is 20K for some reason, maybe that has something to do with it. In any case i want to replace the pot but am having trouble finding a replacement.
Heres the stock pot:
The shaft is about 2cm long and has a very small turning radius
I need one with the same shape so that it fits with the sweeping mechanism, but with a 10k value. Any help is aprecciated
Thanks in advance
Thanks in advance
Roobin
It could be a specialist pot, in which case ask Line 6 for one. Tell them that it was faulty from the off.
