2n5133 tranny's from Small Bear ---- Pinout?
Started by Belt, August 16, 2008, 09:32:47 PM
Belt
Anyone know the pinout for the tranny's?  I can't find it anywhere, and I remember Mark Hammer made a comment about them being different than you'd expect.
Don
All for Him
Nitefly182
Quote from: Belt on August 16, 2008, 09:32:47 PM
Don
If theyre like the pill shaped ones I have then the pinout is just reversed from standard. I dont remember exactly though.
John Lyons
Basic Audio Pedals
www.basicaudio.net/
Belt
I'm not looking for values.  I should clear that up.
Dave, I've heard the same thing.  I just don't know for sure.
All for Him
John Lyons
If you scroll down there is a pinout....
john
Basic Audio Pedals
www.basicaudio.net/
Belt
All for Him
A bargain basement DMM with transistor testing/checking is a handy thing to have in such instances.  You can simply flip the tranny pins around until you find an hfe reading that seems plausible.  Doesn't do you any good for FETs, but it helps a lot with deciphering pinouts for obscure, unmarked, or defaced transistors where getting hold of a datasheet may be difficult..
Belt
Thanks Mark.  I didn't want to mess around with it...  without knowing.  But in the future, I'm all for it.
All for Him
John Lyons
Can't you also measure for the transistors diodes (cathodes) that point to the base?
john
Basic Audio Pedals
www.basicaudio.net/
You certainly can.
And if the device is installed, I suppose that's the most expedient course of action if you can't or don't want to remove the device from the board.
Of course, I personally have yet to find a DMM that will measure diodes but not also measure transistor hfe, so the simplest thing for an uninstalled device is just to pop it in the meter socket, and flip it around until you get a plausible (and informative) reading.
eurekaiv
I found this photo once in another thread...  you've already figured it out obviosuly but this might help folks in the future.
