Vibracaster - or "How to turn your Valvecaster into a Tremolo"
Started by frequencycentral, August 18, 2008, 03:35:10 PM
Franky
Wow, this project rocks!! I think i'm gonna have to design a 12V power supply for all those nice tube projects..  :icon_rolleyes:  :icon_wink:
42
kurtlives
My DIY site:
www.pdfelectronics.com
Quote from: kurtlives on August 27, 2008, 04:28:55 PM
Nice!
What did you build it on? Perf, vero?
Tripad - three holes per pad. I really like it a lot!
Franky
42
col
I need to try that oscillator in a tremelo circuit I've been messing with to see if it cuts out the thump I was getting, not even a tick. What we really need for true vintage mojo is a Ge transistor oscillator. I have tried a few but they have produced ticking, I wonder if this could be adapted to remove it?
Col
Col
Franky
I was just about to talk about that oscillator.. In a different way, using an opamp to get more waveshapes (tri or square, or even a mix)...
42
Quote from: col on August 28, 2008, 04:00:17 PM
Col
Most of the ticking I had to fix was caused by the rate LED turning on and off, only a little from the LFO itself. I found the diode between the wiper of the depth pot and the cathode sorted that out, together with playing about with the values for the voltage divider at the LFO output.
As for Ge - they're really low gain as far as I know (I'm no expert), I think the BC547C I used has a gain of 800. I tried this oscillator with BC107's - it wouldn't oscillate.
Quote from: Franky on August 28, 2008, 04:06:48 PM
You could use a transistor or (opamp) comparator to turn the LFO's sine output into a square wave - but you may then experience ticking. Triangle is so similar to sine (for this purpose) that's it's not worth the extra hassle! And triangle would also probably have ticking problems. The LFO in my other tube tremolo 'Bipolar Disorder' was based on a triangle, I had to work hard to stop thumping/ticking. The nice thing about a sine is it's smooth turnaround.
What I like about the Vibracaster is it's 'vintageness' - old school tremolos used similar sine wave phase shift oscillators - this one just uses transistors instead of tubes. Tubes won't oscillate at 12 volts........
Jimmy-H
OOOoops you did it again!
Nice piece of work Rick ;)
Does it sound different compared to the Bipolar disorder?
And you couldn't help yourself to build the Vibracaster! ;D
Renegadrian
Quote from: Jimmy-H on August 29, 2008, 11:29:54 AM
Thanks Jimmy! I haven't done an A/B test with the Bipolar Disorder yet - I'll get around to it and post some more clips.
No - I had to build it really to get 'closure' - now I can move on to #3 in my submini tube series: "Doppelganger".
And...........if I hadn't built it I wouldn't have sorted out the bugs!
Quote from: Renegadrian on August 29, 2008, 11:31:00 AM
Hehehe - where you get those icons from I just don't know!
liddokun
I can use the 6111 version 2 schematic, but just build it using a 12AU7 right?  The pinout's are just different, but all the resistor values and everything is ok staying the same?
To those about to rock, we salute you.
Here's the 12AU7 version, just the tube pinouts change. The rate LED circuit is optional.
liddokun
liddokun
The circuit can also be run at 9VDC, correct?  If I'm running it at 12V using a wallwart, what should the current specs be for it? 300mA?
And those two big resistors..if I'm building with 12AU7, then I can just use 1/4 watt resistors throughout?
Quote from: liddokun on August 31, 2008, 01:38:20 PM
Correct - but it would have to be the 12AU7 version.
12AU7 version should draw about 150ma.
6111 version should draw about 300ma.
Make sure your power supply is regulated. Maybe you should get a 500ma (or more) so you can power future tube projects.
You only need the big resistor(s) for the 6111 version. To run the 6111 heater from 12 volts you need to reduce it to 6.3 volts. That's what the 19 ohm / 3 watt resistor does. I used two 10 ohm in series - they were 5% tolerance,  I measured them at 19 ohms - perfect!
Alternatively you could use a 7806 voltage regulator (6 volts is at the lower end of the heater tolerance, but it should be fine). Or you could use a LM317 and trimmer (like the Subcaster) and dial it in to 6.3 volts.
Don't forget you could also add all the original Valvecaster controls with a bit of tweaking: Gain, Tone, Volume. I will add a schematic of that version to this thread eventually - but it's pretty easy to work out if you compare the schematics.
liddokun
Hey, thanks for the help.  I saw a few tweaks in the valvecaster forum, specifically using the 7812 on the dc jack with 100uf filtering cap.  Should I add this on the vibracaster?  I'm planning on doing it 9vdc, with a 12AU7 so that I can power it off my daisy chain.  The 7812 is a 12v regulator, so I suppose I wouldn't use it here for my 9v circuit.
Johnny Halo
Can someone post the PCB layout for this in the 12au7 version?
Thanks.
Quote from: liddokun on August 31, 2008, 04:08:00 PM
Don't bother with a 7812 if your'e running on 9 volts. Maybe you could consider a 7809 instead, but build it without first - you may not need it. Use the 100uf cap though.
Quote from: Johnny Halo on August 31, 2008, 04:14:34 PM
Thanks.
Sorry, i don't do PCB - I'm a Tripad guy (see above). Someone else is welcome to come up with a vero layout or a PCB though...............
