Atari Punk Console debug
Started by McGhie, August 26, 2008, 05:47:48 PM
oldrocker
Do you have a pic of the front of the board too?  This might help more eyes looking it over.
any
I think running your jack through the telescopes is possibly doing something to your signal.
I'd say, hook up the circuit as directly as possible in order to trouble shoot it.
Also, the ground and pot connections don't look good, how have you measured the connection?
Did you measure for continuity or for zero ohm resistance? (or both)
Take the time to get the soldering right, saves a lot of frustration...
That said, It looks very funky!  :D
It's supposed to sound that way.
McGhie
#22
Quote from: oldrocker on September 02, 2008, 05:57:16 PM
Will take one ASAP!
Quote from: any on September 02, 2008, 09:39:32 PM
About the telescopes, I thought so. But the volume doesn't seem to change extended/unextended. Guess I'll give it a try though. ;)
I measured all wiring with the pins on the opposite ends of where the wires meet, on the copper strips when possible.
Continuity? Zero ohm resistance? I may or may not have done this, naming it differently, please elaborate?
Thanks! I must admit that I am of the same opinion! :D
Builds in process: NPN Boost, Atari Punk Console (standalone), Underfuzz
any
Quote from: McGhie on September 03, 2008, 03:14:02 PM
If you measure on your DMM, which setting do you use?
the one that measures resistance (o-200 Ohms).
or continuity (the diode shaped setting) which tells you whether electrical current goes through.
(at least that's what I think it does...)
Anyway, how do you measure your connection?
Also, what wattage is the solder iron? maybe it's to low or high for this kind of work.
The chip might be shot by the excess heat on the components..
It will work...eventually!
McGhie
Quote from: any on September 04, 2008, 05:52:13 AM
Ah!! I measure resistance then. But with your explanation, the other one sounds simpler.
My soldering iron is 35 W. I know that it should be 15-30, but 35 seems fine, I can easily get the job done before anything overheats. Except maybe for chips and trannies, but I solder with them out of their sockets.
I know, and it pisses me off that it isn't now! :D
