How to design layout to print e stick on my enclosure?
Started by spatescroll, August 29, 2008, 08:39:02 AM
spatescroll
Wich is the easier solution to create a good layout to print and stick on my enclosure? I bought a trasparent sheet to print on, and another question is how to print only in white on this.
I do all mine in Microsoft publisher - suits my needs. Though I did have a friend do me a more complex synth layout using CorelDRAW.
I use transparent OHP sheets, I print a reverse image on the back, so the finished graphic is well protected.
You can't print white - but what you can do is print off your graphic - the white areas will print clear - and then spray the back with white spray paint or similar.
spatescroll
So being black the enclosure, maybe would be better yellow or red...
