Help me identify this cap/resistor combos fuction
Started by John Lyons, August 29, 2008, 02:57:03 PM
John Lyons
At the bottom:
With the 330n/1k combo to +vb, is this forming a shelved low pass filter?
If I reverse the combo to 1K/330n to +vb how will this affect the filter, or will it?
Or, is the 1k5/330n/1k tapering and changing the pot's resistance as filtering a bit?
My main concern is whether the cap/resistance order of the 330n/1k matters if it's reversed.
thanks
john
Basic Audio Pedals
www.basicaudio.net/
Sir H C
Doesn't matter if it is reversed as that middle node is not tapped.
John Lyons
Thanks Chris
Is the combo providing a LPF for depending on the setting of the pot?
The pot comes after the combo so maybe not.
Can anyone explain what is going on in that pot/cap/resistor cluster?
thanks
john
Basic Audio Pedals
www.basicaudio.net/
Sir H C
The curse is that with a 100k pot, it will do practically nothing until that last little bit of the turn.  the RC is a shelving low boost (or more correctly highs attenuation).  But odd that it doesn't have anything tapping out at the top of that stuff, only above the high pass, so together a sort of band pass?
John Lyons
So at full CCW is the (possible) bandpass correct?
thanks for your time checkig this out.
john
Basic Audio Pedals
www.basicaudio.net/
Sir H C
Yes, if you think about it, when the pot is ~3k and above it is out of the equation, so for 97% of the rotation, nada.  Do you have a bigger picture?
