Never Mind Figured it Out...Trotsky Vero layout inside
Started by kurtlives, August 30, 2008, 06:46:24 PM
kurtlives
Got my Trotsky drive working (finally). Decided that I wanted to put the final build on vero as the PCB I was using was falling apart.
So I built it on vero making a layout as I went along...
Here is the schem...
Here is my layout...
Can anyone see any errors? Yes I subbed a 600R resistor for a 680R. In my PCB build I used a 740R though and had fine results.
I also left out the bright cut for now.
I get audio but it is very low output and farty and bassy. Mis-biased?
Thanks...
My DIY site:
www.pdfelectronics.com
kurtlives
Consider that vero layout verified!
Stupid wiring error on my part, it works.
My DIY site:
Focalized
The strip for gain 3 and 9v don't connect to the rest of the circuit. Missing a jumper?
Quote from: Focalized on August 30, 2008, 08:09:10 PM
Nah, the 3k3 is in series fom 9v to the pot - so the layout is correct!
kurtlives
Yep its correct! Of course when you build it you can tighten things up a bit but anyways...
Fun effect...
My DIY site:
