Birth of a Wah Enclosure... (Tons of Pics... 56K Warning!!!)
Started by MicFarlow77, September 02, 2008, 12:38:14 PM
MicFarlow77
Hi All,
This post and a few that will follow is a build report (with tons of pics) of a bunch of 12 wah casings I started over the weekend! (9 are available for sale)
This first post will detail the build segment for the sides of the enclosures.
First things first.... Every enclosure starts as a side profile. The Wah Casing side profile is a bit over 30" long.
Now, Got to bend them corners. To do the corners consistently, I devised and built a Uni-tasker for just that purpose. Basically, it's a car jack, some pipe, some wood and some acetal plastic.
Another view.. bit closer up....
Basically, I put in the side profile, crank the jack a couple of times and presto, a perfect 1" corner is created.
This is the left rear corner...
This is the left front corner...
Halfway there....
Right rear corner...
Right front corner...
All bent up....
Next I need to weld it up... Here you see my spool gun welder... for a size reference, the enclosure is 10 inches long...
All welded up.. one drawback to the MIG welding process is the spatter... but it cleans up easy enough...
Repeat this process 11 more times and you have....
Later I will post the process for doing the bottoms!
Thanks,
Mick
foxfire
i love your simple press idea. i need to remember that one.
rylan
nelson
My project site
Winner of Mar 2009 FX-X
Boogdish
MicFarlow77
Quote from: nelson on September 02, 2008, 12:49:14 PM
Put me down for two!
:icon_biggrin: :icon_biggrin:
Hey Paul,
I got ya.... I'll post in the For Sale section a little later today. For all those that want one, I'll need additional info before I can do the paddle. Keep an eye out in the For Sale section....
Thanks,
Mick
Auke Haarsma
Really cool to see the process!
Keep it up Mick, I'm sure they (including my 2 ones!) are gonna be awesome!
Auke Haarsma
They also look very 'shiny'. More shiny than the ones in the previous pics. Is that part of the process? Can you keep them that shiny (if possible, I'd love that!)
MicFarlow77
Quote from: Auke Haarsma on September 02, 2008, 01:02:14 PM
Hey Auke,
I wish I could keep them that shiny but it is not possible. What you are seeing in these pics is the raw aluminium. As this post progresses more, you'll see why I am not able to keep them that way.
Thanks,
Mick
MicFarlow77
Quote from: foxfire on September 02, 2008, 12:43:35 PM
rylan
Hey Rylan,
I like simple too.... this is about the 3rd or 4th incarnation of bending rigs or presses... this one is by far the most consistent. I have some additional improvements planned for this one as well, but probably won't have time to get to them until much later in the year....
Thanks,
Mick
foxfire
Quote from: MicFarlow77 on September 02, 2008, 01:28:11 PM
rylan
Hey Rylan,
Thanks,
Mick
i'm a cabinet maker and one of my most favorite thing to do is make jigs/forms/tools. my most favorite thing to do is make a better jig/form/tool than i did the time before.
rylan
John Lyons
Basic Audio Pedals
www.basicaudio.net/
Auke Haarsma
Just bumping it in the hope that there's more pics coming!
petemoore
  thanks cause I missed this thread somehow the first time it went down the list.
  Great thread starter BTW.
  The process and the product are both really cool and seem kinda new here to me.
  Welder really helps that '5th step'...a hurdle that could be overcome in a less elegant fashion I suppose.
MicFarlow77
Hi All and Many Thanks for the comments!
Here are some more pics of the next major phase of any of my enclosures.. the bottom. Due to the way the bottom is recessed up into the enclosure, I actually do the bottom and get it all finished before I do the top. It is also a little easier since I can trace out the bottom easy enough, since my enclosures will have a small amount of variance from one to the other.
So, oversized bottom plates are cut out, have a piece of plain paper glued onto it and they are also numbered and matched to each of the side profiles so that they all match up in the end.
Once this is done, then between the bandsaw and the belt sander, they are cut to size and have thier corners rounded. I also sand them up to make sure that all the burs are all gone.
All 12 of them...
With the bottom plates done, I have to cut out the cleats that end up getting welded into the inside corners to hold the bottom.
I use a simple little gig to hold them cleats just right... This jig holds the cleat exactly .080 above the bottom edge of the side profile..
Ready for a pop from the welder to fasten it to the side....
All done... now to do the other 3 corners... Once all corner cleats are in, I tape in each respective bottom to get ready for drilling and countersinking
Here, you see number 12 getting drilled for the bottom screws... I drill from the upright side... pretty easy this way since the top is out of the way...
With it drilled, I now use a special ZErO Flute countersink to countersink each corner....
All countersunk and ready for the bottom plate.
Now, with the bottom in, I take it back over to the belt sander to get rid of the extra weld material from the front side of the side profile.
All 12 bottoms in....
At this stage, I am roughly half way through in terms of process steps, but a little less than half way through in terms of time spent per enclosure. Getting the tops bent, welded on, trimmed up, brazed in and sanded will take a bit of time.
More to come later!
Thanks,
Mick
John Lyons
Go Mick go!
Thanks for taking the pics as you go along. Love it.
john
Basic Audio Pedals
www.basicaudio.net/
Auke Haarsma
MicFarlow77
Quote from: John Lyons on September 04, 2008, 04:09:59 PM
Go Mick go!
john
Thanks John,
What's neat about this whole process is that no matter what size or type of enclosure I build, it has to go through the steps shown here. There are some variations depending on the tops, but at a minimum, it will have to go through the steps shown here.
I have some pics of the top process that I will try to post later tonight or tomorrow. If I don't, I think Auke is going to come get me....  ;D ;D ;D
Thanks,
Mick
letsgocoyote
mike_a
Wow Mick!  :o
That is mechanical workmanship at its best! I'm in awe...
I'd love to see the rest of the project.
Keep those pictures coming  :icon_wink:
Auke Haarsma
Quote from: MicFarlow77 on September 04, 2008, 04:20:18 PM
Uhm, *ugh ugh*, I am sure I do not have to remind you that I do happen to know where you live...
;) :icon_mrgreen: :icon_mrgreen: :icon_mrgreen:
Any chance you could make us happy with some more pics?
Much appreciated!
