Buffer.. erhm which one?
Started by Beros, September 04, 2008, 08:02:41 AM
Beros
Hi.
I'm thinking about putting together a buffer, but I have no clues on what circuit to use. I'd like it to be as transparent as possible. The fewer parts, the better. So should i go IC or transistor? Schematics are appreciated.
Man ska inte ligga med lik
Gus
Good thing to do is type "buffer" in the search and read a bunch of posts.
guitarman89
try the ggg buffer. it works well!
built: MXR Dist+,dod250-280,dr boogey,IC buffers,cmos drive,multiface,20W SS pwr amps,phase90,tubescreamer,rat,amzMB,wuly mammoth,dod280,zombie chorus
under constur:60W 3886 amp,jcm800 em
www.myspace.com/guitarmanbll
www.myspace.com/filospinatopunk
  Depends what you want besides, and how much current amplification.
  But any active buffer output is going to be able to drive much more current than a guitar pickup.
  They're all nearly 1:1 voltage amps, which = low distortion, IC reports: may sound 'cold or Sterile', mostly I use a Jfet or what is easiest to bias with the PS I have available.
frank_p
