Sample & Hold -> is this right to get a CV?
Started by brad, September 14, 2008, 08:27:40 AM
brad
I'd like to use a sample and hold as a control voltage, and found this really cool little circuit...
http://www.super-freq.com/wp-content/uploads/2008/03/bdm_sample_anf_hold.jpg
To get just the CV without the audio part, would I just use the section of the circuit going to R6 and into the FET?
"If You Can't Open It, You Don't Own It"
The opamp at the top forms a clock oscillator to turn the FET on and off.
The S/H happens between TL072A and TL072B. C1 is the 'hold' cap.
If you feed white noise into this circuit you will get a random voltage output.
So you need the entire circuit plus a white noise source.
brad
brad
Whoa!  I like that one.  Makes me wish I had a use for the trigger output  ;D
A midi clock input would be pretty interesting on a sample & hold I reckon.
flo
#6
LF398, Sample & Hold with 1 DIL8 chip, $1.80 from Futurlec:
http://www.futurlec.com/Linear/LF398N.shtml
http://www.datasheetcatalog.org/datasheet/philips/LF398_2.pdf
Much simpler than a discrete build...
