DIEFET: A French Diezel VH4 Jfet Simulation
Started by ech0es, September 16, 2008, 04:03:39 PM
Ripthorn
I made the V1.2 mods on a V1.1 board, you can put the cap on the gain pot itself and then the other values are just changes to the values (no new locations, really) and make sure that the deep pot only has the two lugs wired.  Takes about 5 minutes.
Exact science is not an exact science - Nikola Tesla in The Prestige
https://scientificguitarist.wixsite.com/home
kupervaser
Thanx,
Is there anyone who can tell me whether i can fit this pedal into a BB enclosure with battery?
ech0es
battery means 9v, the diefet will sound much better with higher voltage
kupervaser
hey Echoes, what is the right voltage for it? 12 or 18?
Could you send me some pics of the guts of this pedal? Can i fit it in the BB enclosure?
THanx
Jeff
ollie
Quote from: ech0es on March 25, 2009, 08:43:27 PM
But I could run it from 9V DC Adaptor and add a voltage doubler like this one: http://www.elecfree.com/electronic/voltage-doubler-with-ic-555/
Says it has low output current so stick a tranny follower on the end maybe? 18V should make it sound pretty good I would've thought
The duty of youth is to challenge corruption.
Ripthorn
I run mine off of 12V and as far as box size, I would think it would fit in a BB, though the box mine is in is one I made (inner dimensions of approximately 4.5"x3.5").
kupervaser
Thanxa a lot everyone. I think  could build a voltage doubler.
ech0es
my diefet has a voltage doubler in it with a max1044
kupervaser
Hey Echoes, can you send me some pictures with the insides of your pedal? I want to see how to fit it in the enclosure:
please email: angar666@hotmail.com
Thanx
Jeff
ech0es
i can't take pictures, but the pcb AND a battery fits very well in a BB enclosure,(and with a voltage doubler!)
kupervaser
In your first post it sais:
Dimensions : 135 x 44 mm
The BB enclosure dimensionds are:
119x93,5x34mm
Are you using a different layout? Because this lay out won't fit.
If you are using a different layout, could you post a link here?
Thanx in advance,
Jeff
ech0es
ollie
I got my PCB through  ;D
Looks nice and shiny  ;D
Unfortunately I don't have a clue where to put anything; thus follows several evening of research...
kupervaser
Thanx, i am starting to build this thing. Probably going to make the enclosure myself.
kupervaser
Thanx for those links, however:
119x93,5x34mm
Apparently this layout won;t fit in the BB enclosure. Can someone show me a layout which can fit in the BB enclosure if someone has built it that way?
Thanx a lot
Ripthorn
One of the other members has a smaller layout, you could PM him.  I don't remember his username off the top of my head, but I think it is gkoersman.
kupervaser
THanx
I have another qustion. How should i adjust the trimpots concidering i am using a voltage multiplier from 9 to 18 vots?
Ripthorn
kupervaser
Hello everyone,
I assambled the pcb yesterday and tested it. However all I get is oscillations.
I measured the voltages and it seems to be all good. I also checked the whole pcb with the schematic and the values are correct and it seems i haven;t made any mistakes during soldering.
This layout has been used:
This schematic has been used:
I checked with hte audioprobe and the oscillations start just after C11, the side which goes to the treble potmeter. I can hear good aplified and high gain sound on the source of the Q5.
The controlls don't do much. Volume works well, gain is very low. When i put the deep potmeter on 0 I have low gain sound, when I turn the Deep up I get oscillations almost immidiately. The sound I hear is similar to the Fuzz Factory.
I don't know where to look any more, I checked the pcb very thoroughly.
I used a voltage doubler, which gives me around 17,66 volts on the output. I adjusted the trimpots so the transistor recieves the half of the voltage. But the trimpots don;t really do much in my case at the moment.
Has anyone had this kind of a problem?
All the help is appriciated.
