searching this type of led/neon indicator !
Started by bent, September 18, 2008, 11:40:19 PM
bent
hello,
anyone know where to find this....
i'm searching the type of indicator that cornish use on is equipment...the clear lense....and if you look the picture in the bottom they look as big as the stompswitch... i dont know if they are led, neon or lamp....
http://www.petecornish.co.uk/6channelampsplit.html
they are not the same of the stand alone pedal....
thank's
bent
Long live the music.....
bent
pjwhite
I don't know if this is the exact same type of indicator, but DigiKey has the following series you might want to look into:
http://search.digikey.com/scripts/DkSearch/dksus.dll?lang=en&site=US&keywords=L16PLR10&x=0&y=0
I'm estimating from the photo that these are 18mm panel indicators.
bent
