How can i obtain +/- 15V from a 9V wallwart?
Started by gigimarga, September 19, 2008, 04:28:10 AM
gigimarga
Hello,
I want to build an effect that use +/-15V obtained from a 40V supply.
It's possible to get +/-15V from a 9V wallwart?
Thx a lot!
liddokun
Perhaps use a charge pump to double the 9v and then a voltage divider?
To those about to rock, we salute you.
gigimarga
It's easier to get +/-15V from 18V or 24V?
Anyway, which is the lowest voltages from which i can obtain easy +/-15V?
Nasse
If you use regulator chips you can look the data sheets what they need for input. Perhaps you can do with +/- 8, 9, 10 or 12 volts or get another transformer
