Quick verify needed.
Started by stompbox steve, September 19, 2008, 11:28:34 AM
stompbox steve
Hello
I am putting a Volume pot in my new Nano Bassballs and just wanted to make sure this would work.  I have searched and found this:
What I did was add a very simple Volume control at the end of the circuit. I used a 100K Reverse Audio pot. I took the wire from the PCB out (that goes to the 3PDT Return) and soldered it to lug 3. Lug 2 goes to the 3PDT switch where the wire from the PCB went and lug 1 goes to ground. I hope that makes sense. Now I can turn it down when the Dwell is down and back up again if I turn the Dwell up.
now everything is board mounted and I am thinking I could put the Pot between the switch and the output jack instead of mentioned above: between the board and switch.
Shouldn't make any difference, right?  I will be able to see which lug of the 3PDT is connect to the output jack with my meter and just cut that wire and follow the directions as stated.
I added a bad pix of the guts: http://s6.photobucket.com/albums/y229/stompboxsteve2112/?action=view&current=Nanobassballs.jpg
Just wanted to make sure before I changed anything.  Much Thanks, Steve
Funk it up,
Steve
theehman
If you put it between the output jack and the switch, you lose your true-bypass AND the pot will affect your clean signal's volume.
Ron Neely II
Electro-Harmonix info: http://electroharmonix.vintageusaguitars.com
Home of RonSound effects: http://www.ronsound.com
fx schematics and repairs
stompbox steve
rats   :icon_mad:
do you have any idea which of the lugs I would need to "jump in on"? based on the picture I linked before?
or how I would determine which one?  I have a old schematic but not sure how that has changed with the Nano line?
I already killed an older bassballs with these mods but wanted to smaller footprint of the Nano.
any direction is appreciated, Steve
Funk it up,
Steve
asfastasdark
Is the switch soldered onto the board or attached to it with wires? If it is the last, you can add a volume control between the board and switch.
theehman
Quote from: stompbox steve on September 19, 2008, 03:14:09 PM
rats   :icon_mad:
Here's a pic.  I took mine apart, traced it out, and scanned the switch board.
Free Image Hosting by ImageBam.com
Ron Neely II
stompbox steve
you know what, you are the man  :icon_cool:!!
Thanks so much, Steve
Funk it up,
Steve
