9-to-18-volt convertor
Started by Artie, September 20, 2008, 07:22:46 AM
Artie
This looked like something that folks here might find interesting. Its a simple voltage doubler that I found while troubleshooting a friends Yamaha active bass.
Here's Yamaha's take:
(Note: Yamaha uses little up/down arrows to indicate the +/- 9-volt outputs.)
The TC7662 chip has been superceded by the TC962. Here's my take with the newer chip:
Here's a source for the TC962 datasheet: http://www.datasheetcatalog.com/datasheets_pdf/T/C/9/6/TC962.shtml
theehman
So, it's not really an 18v supply but a +/-9 v supply?  Still interesting and handy.
Ron Neely II
fx schematics and repairs
Artie
Right, but you could use it as an 18-volt supply just by isolating the convertor ground, and using the -9 as circuit ground.
