HELP!! Debugging Rebote 2 Delay pedal
Started by mitzrecords, September 25, 2008, 12:55:16 AM
mitzrecords
http://www.tonepad.com/project.asp?id=27
hi, so i made this delay pedal a while ago. it didnt work but i figured it out that opamp was bad and replaced. and it worked!
today i went to play it but all of sudden again!, it doesn't work. bypass is fine but when pedal is on, there is no sound. I went through debugging and checked connections etc. but seems like parts are bad maybe?
i measured the voltage throughout I noticed pin #3 of IC PT2399 is zero and pin #4 of IC TL072 is also zero.
what does this mean???
please help me!!
im so frustrated as it was working...
ppatchmods
I would also like some help on this. I have 2 rebote 2.5's that have been subjected to ac power(not by me) and no longer work. They both power up but no sound when engaged.
When your life is over, will any of this STUFF really matter?
Auke Haarsma
check the schematic. Pin 3 of the PT2399 is connected to GND, 0V reading is ok. Same goes for pin 4 of the TL072.
AC could mean trouble. Post voltages on all IC's.
mitzrecords
Hi, thank you so much for reply!!
Here are the voltages on ICs
IC 1 Delay Chip
1 --5
2 --2.5
3 --0
4 --0
5 --2.3
6 --2.5
7 --0.6
8 --1
9 --2.5
10 --2.5
11 --2.5
12 --2.5
13 --2.5
14 --2.5
15 --2.5
16 --2.5
IC2 Op Amp
1 --4.6
2 --4.56
3 --4.62
4 --0
5 --3.46
6 --4.4
7 --4.4
8 --9
i heard that pin 5 on op amp should be higher. if op amp is not working properly, this is really strange since i replaced it before because it wasnt working and after i put a new op amp, it was working for a while but all of sudden, no sound when on.
so if i have to replace op amp, this will be second time in really short period of usage. maybe i have something else wrong?
thanx!!!!
Auke Haarsma
Voltages look ok.
Do you get a sound out of Pin 14 of the PT2399?
mitzrecords
Quote from: Auke Haarsma on September 25, 2008, 11:23:10 AM
Voltages look ok.
sorry. what do you mean by that? do I just tap it plugeed it literally to get a sound?
Auke Haarsma
you could use an audiopobe (check geofex.com).
I just 'plug in' there. If you can visualize with an oscilliscope that's easier ofcourse. But not everyone is so lucky to have a scope at hand ;)
mitzrecords
Quote from: Auke Haarsma on September 25, 2008, 11:47:56 AM
ohh ic
thanx for suggestion. i have to order parts now. just curious is there any other way as well?
thanx
Auke Haarsma
no need to order anything. Just connect a wire to a jack. Connect to other side of the wire to whatever you wanna listen to (in this case pin 14).
mitzrecords
Quote from: Auke Haarsma on September 25, 2008, 12:13:44 PM
thank you auke.
so plug in 1/4" cable input and 1/4' cable to amp and input cable touch that pin 14 to hear noise through amp?
Auke Haarsma
Almost ;)
2 cables:
1) Guitar -> Jackcable -> Input of Rebote.
2) Amp -> jackcable -> jackbus (connect sleeve to ground). Tip of jackbus to a wire. That wire you can use to listen to the signal anywhere you plug it in.
mitzrecords
Quote from: Auke Haarsma on September 25, 2008, 12:38:32 PM
Almost ;)
2 cables:
:icon_redface:sorry auke. i sound dumb but jackcable means ordinary 1/4" guitar cable?
jackbus?
thanx
Auke Haarsma
No need to say sorry, I should have been more precise!
jackcable is indeed your normal guitar cable.
jackbus is something like this:
or
mitzrecords
Hi, Auke. thank you.
I just tested the sound. I get sound from any pins of Dealy IC.
Auke Haarsma
mitzrecords
Auke Haarsma
You should only get sound on Pin 16,15,14 of the PT2399.
I suspect something went wrong with the audioprobe.
mitzrecords
Quote from: Auke Haarsma on September 25, 2008, 02:56:00 PM
oops  :icon_redface: you were right.
i got sound from 14 15 but not 16.
and those sound i got was delay lay lay lay>>>>>
exciting!!
mitzrecords
Auke Haarsma
yeah seems like the PT2399 is working ok.
Now follow the signal to the Repeats and Level pot. Still good sound?
