CD4000 based stompboxes: are they noisy?
Started by DDD, September 27, 2008, 01:36:03 PM
DDD
As far as I know, MOSFETs have some times more noise and hiss relatively to the JFETs and BJTs (in the electric guitar applications such as input stages of the overdrive and fuzz circuitry). Is it true?
CMOS CD4000 logic ICs are used in some famous gadgets like Red Llama and Tube Sounding Fuzz. They say that these stompboxes have a good sound and high gain abilities.
But I didn't find any opinions on their noise (hiss) properties in comparison with the discrete JFET and BJT circuits.
Are there any opinions and experience out there?
Any information on the subject is appreciated.
They are known to vary with chip.
When synth-builders are putting together a noise generator circuit, they are always advised to test out a bunch of transistors and select the one the produces themost noise.  These are transistors of the exact same part-type (e.g., twenty-five 2N3904s).  So, when you look at what is inside a 4049 chip and realize it really is only a couple of transistors per invertor, it should not surprise you that they too can vary in noise produced, even though they may be produced by the same company and have the same part number.  So, try a few out and select the one that yields best sound with lowest noise.
Beyond that particular aspect, you can always tame hiss by adding lowpass filtering on .  Personally, I prefer to add more on at the beginning and then ease up a bit toward the last stage/s.  There are two reasons why.  First, gain is multiplicative, so that if there was any hiss in the source signal, boosting it, and then boosting it again, is going to give you a hissy output.  Second, when you apply lots of gain to a signal in a stage that is intended to add harmonic content, you end up with harmonics of everything, including noise in the upper mid band.  If you boost and clip that again....well, you get the idea.
So, I like to impose a rolloff around 3.5khz or less at the beginning (sometimes lower) and then ease up to a rolloff in the 4-5khz range near the end.  I won't claim that this necessarily gives you a dead quiet effect, but it does give a VERY quiet overdrive, with a very pleasing tone.  Many pedals, in an effort to be flexible, provide more bandwidth than is actually needed.  One needs to pick the bandwidth that you absolutely can't live without, and design around that.  You may find that very often you have more bandwidth at either the top or bottom than you really need, and a little more bass or treble-trimming nets you less audible hum or hiss.
It pays to have a lot of small-value caps (33-470pf) handy.
DDD
Thanks, Mark.
Your reply can clarify the situation with the opinions in the guitar-sound part of the Russian Internet ;-). Some guys describe their CD4000-based stompboxes as extremely hissy, some others are quite happy with the noise properties.
But please note that nobody say that CD4000 ICs are dead quiet. So did you.
Well, what should we expect from the binary-oriented chips? They do their work well.
Also, having read some your recommendations to use CD4000s as a good clippers but not as an input gain stages, as well as your excellent explanation on the filtering principles, I have to thank your once again.
From Canada to Kazakhstan, you are welcome! :icon_biggrin:
