Adding a rate indicator to the Vox Repeat percussion.
Started by breather-resistor, September 28, 2008, 02:06:49 PM
breather-resistor
Hey everyone,
I have recently built the vox/jen repeat percussion via the Analoguru schematic.
<img src="http://analogguru.an.ohost.de/193/schematics/Vox_RepeatPercussion.gif">
I am interested in adding a rate indicator.  Based on the knowledge that I have so far I expect to tap into the voltage somewhere around the unijunction transistor.  I am more concerned about implementing the rate indicator without detracting from the depth of the circuit as I know surges of voltage create the effect.
Any ideas?
Geoff
spudulike
Effect is by Q2 dropping signal to earth, the ujt feeds Q2 base.
Try this with a 2n3904 ...
Q2 base -->10k-->2n3904 base.
+V-->1k-->LEDa/LEDk-->2n3904 collector
Gnd-->2n3904 emitter
May need to adjust R values.
breather-resistor
Thanks for your info.
Ok, I remember now, Q2 drops the signal to ground at a rate triggered by the unijunction.
I took your suggestion to make this schematic,
Is that correct?  I also tried it with the led in series to anode towards 9v cathode towards collector.
The result of the schematic above was a steady dim light through the LED with no pulsing at all.  The rest of the circuit is fully functional and I just banana clipped to the breadboard to attempt the circuit suggested.
Any ideas?
Geoff
gigimarga
Can you post a soundclip with it?
I am very curious how it sounds...
breather-resistor
Spudulike- ah yes, a second look at your post and I can see that by Led/a Led/k you meant anode and cathode.
I tried this and the result was identical, lights up, no pulse.
Gigimarga- I will indeed post a clip with it.  My interface is being goofy right now or else I would have posted it with this message.
Its definitely a a niche pedal.  It certainly needs a little help from the core schematic.
Eagerly awaiting any ideas.
Geoff
Br4d13y
freedom is the freedom to say 2+2=4
tenser75
did anybody solved this? im curious as well to add a pulsating led thanks
blackieNYC
In that drawing I would expect the LED to be constantly lit. 9v->1k->LED->gnd.
Take a look at the cardinal tremolo schematic.
