tube at 9v
Started by Br4d13y, September 29, 2008, 09:55:21 PM
Br4d13y
are there any 9 pin tubes that can run and get decent saturation at 9v power?
freedom is the freedom to say 2+2=4
mac
iirc 12au7 was designed for 12v.
mac
Br4d13y
are there any subminis that run well at 9v?
nordine
Br4d13y
What size resistor would be needed to take 9v to 6.3v?
Quote from: Br4d13y on September 30, 2008, 02:26:25 AM
2.7 volts / 300ma = 9 ohm
2.7 volts x 300ma = 0.81 watt
So a 10 ohm /1 watt would give 6 volts (within the heater's tolerance) and handle the heat.
Or just use a 7806 voltage regulator.
Br4d13y
Sweet , I am gonna use ranks tube as a diode in my ts 808 clone. The real TUBE screamer :icon_mrgreen:
petemoore
  I forget what all was said about just throwing a tube in a TS, because it's that picture near the bottom at GEO 'how to get tube sound in a stompbox' IIRC, it showed a hammer being used to 'fit' a tube in the TS.
  Whatever it was, messing about @ low voltage with tubes should be good fun !
Renegadrian
You might want to try the 9AU7, which is the 12AU7 sister, only difference being the heater voltage. You can find one darn cheap thru the 'bay...
Br4d13y
Quote from: Renegadrian on September 30, 2008, 08:37:40 AM
what is the gain on that?
Renegadrian
