Shocktave Debug - Help with transistor voltages
Started by bdevlin, October 01, 2008, 02:18:52 PM
bdevlin
HELP!
I used this circuit: http://www.diystompboxes.com/analogalchemy/sch/shocktave.html
I corrected a transistor orientation issue but I still have transistor voltage readings that are suspect.  I hear the octave but I don't believe the performance of the circuit is up to par.  Hell, I can remove Q4 and it does not impact the circuit to my ears.  I found a note that said that the collector voltage for Q2 should be ~4-5v.  My Q2 collector is 8.9 V with a 9.6V battery.  I have checked my wiring and can't find an issue Other voltages are:
Q1
E: .96
B: 1.38
C: 9.6
Q2
E: .31
B: .95
C: 8.9
Q3
E: cycles down to zero
B: cycles down to zero
C: 9.25
Q4
C: cycles down to zero
Q5
E: .96
B: 1.38
C: 9.6
