Phase 90 op amps?
Started by jaysg, October 07, 2008, 12:36:14 PM
jaysg
I'm building up a Phase 90 and I need to either order some op amps or put in sockets.   Are there are better op amps for this than the TL071 ?
DougH
Yeah, TL072. It's "1" better... :icon_mrgreen:
Seriously TL071/72 sounds fine in this circuit. :icon_wink:
  TL072 is Dual OA
  TL071 is Single OA.
  Pinouts on the board assigned to a dual layout won't accomodate a single oa, the pinouts are completely different. Choose the opamp, then the layout or vice versa.
Dai H.
AFAIK early one used six single (741), the later version had slightly different circuit and used three double (TL062)
jaysg
I had either a Script or an early block logo unit...don't remember...the box showed the script model.  Anyway, having foolishly sold it in the late 70's, I borrowed a '78 (or thereabouts), and it sounded very different.   I didn't like it at all.  I'm fairly sure the one I owned, had the 741s in it.   There was some noise or distortion.   I believe that was from the FETs.
pete -- I think DougH was making a joke with the part numbers.
  I built one with duals, TL082, different duals tried.
  Then I got a kit with LM741's, not all that noisy, definitely a different sound too. How much of that was attributed to...everything else...[tolerances and layouts mostly, also a 'depth' knob I like, I used film caps on both], I'll never know for sure. 741's I think are a little less 'pristine' and that's part of the difference.
DougH
#6
I seriously doubt you're going to notice much difference between op amps with this circuit. Maybe - but it will be pretty subtle.
Most of the sound difference between "script" and "block" Phase 90s can be attributed to the presence/absence of the feedback loop with the 22k. The feedback loop is responsible for the "midrange" and "distortion" sounds that people don't like.
Edit: I almost forgot- here's pics and soundclips of a Phase 90 I built with TL072 and no feedback loop (like the script):
http://www.aronnelson.com/gallery/main.php/v/DougH/phaser/
I used a Tonepad PCB, which makes it real easy. I spent a lot of time with this on the breadboard before I built it. In the end, all I did was leave off the feedback loop and bump up the gain of the output stage slightly to keep the volume consistent with the bypass volume.
Baziiil
I've got a question. Which transistors did you used in p90 ?
DougH
jaysg
Really?  That's an NPN, not a JFET.
DougH
Yeah, that's for the output stage.
For the JFETs I used some matched J201's.
Sorry, when people say  "transistor" I automatically think "bjt". I forgot all about the JFETs... :icon_wink:
Dai H.
mine is an early Jim Dunlop MXR with the later circuit (and 3x TL062) which I modded to earlier cct. thx. to info found on the 'net. I've tried swapping 1458s of different brands and the original TL062, and there is some difference but not gargantuan. I like the way it sounds now better but need to figure out how to lower the (LFO?) thumping. Also Dunlop is making the older version again called the '70-something(?) Script(?).
