Boss DD-6
Started by Ripper, October 07, 2008, 07:21:40 PM
Ripper
Is it possible to mod a dd-6 to increase the amount of loop time it has?  I know the new dd-7 has 40 seconds, and was wondering if it might be possible to get a little more out of the dd-6
analogmike
It uses a proprietary computer chip for processing the delays, so you cannot modify how it works. There is a super long delay time option that uses the B output, check the manual for more info.
DIY has unpleasant realities, such as that an operating soldering iron has two ends differing markedly in the degree of comfort with which they can be grasped. - J. Smith
mike  ~^v^~ aNaLoG.MaN ~^v^~   vintage guitar effects
http://www.analogman.com
Ripper
It doesn't effect the hold time unfortunately.  That is what I was hoping I could increase on it.
mark
Hi , I was seaching for the same thing. I also use my dd-6 to practice leads with and 5 seconds is just barely enough most of the time. There must be a way to increase the memory for more time in the loop. I didn't realize the dd-7 had 40 second memory.  With 40 seconds i could fit a whole song in the loop or even a 12 bar blues run!
