2 Loop bypass box - with a difference!
Started by kev93_10, October 22, 2008, 03:42:50 AM
kev93_10
I need to build a 2 loop bypass box for someone, but there's a problem. One loop needs to be before the amp and the other needs to be the fx loop. Therefore, each loop needs to have a separate input & output. This should explain better :
What I need to know is about potential ground loops, etc.
Should I use a buffer?
If so, on both loops?
Any thoughts?
Thanks in advance
Kev
