1590B Drill Template for the Peepls
Started by bean, November 10, 2008, 07:47:41 PM
bean
Here's a drill template I've been working on for a standard 3-knob box. It will accommodate a 2"x1.75" PCB, although you could probably squeeze something a bit bigger in there. Be sure to set the DPI to 300 before you print.
Clickey for Biggey---
Zben3129
Thanks, Nice work!  ;D
Templates make everything so much easier.
Zach
bumblebee
flo
Zedmin_fx
can I get some help making this smaller so it will work, it prints out way to big and i have no idea how to fix that
flo
Load it for instance into "Microsoft Paint" (comes with Windows) and scale it down using:
Image -> Stretch
jman 31
For what it's worth, I have found that saving images as a pdf makes it a lot easier to keep the scale. I will however be impossible to edit it on the other end. :icon_confused:
