I want to remove the rectifier and regulator from my DEM...help?
Started by sjaltenb, November 13, 2008, 06:26:16 PM
sjaltenb
Hey again,
Looking to remove the regulator from my vintage deluxe electric mistress. its the one with the internal transformer. I want to use my own power supply so i do not have to run AC to the board. Just wondering what componenets I would need to remove (if any) and where i can "plug" 12vdc+ into the board. heres a schematic: Mine has a 78L12 541Pregulator, just a small one, looks like a normal transistor maybe its a to-92 package
I cant find a schematic anywhere that has that particular regulator setup...but, theoretically...couldn't I remove the regulator and simply plug in at its output? It might go through further filtering but...so what..?
Also, does anyone know how much current these things pull? I guess it cant be that much the regulator is rated at 100ma.
http://www.futurlec.com/Linear/78L12.shtml
I guess thats whats in mine...
theehman
Quote from: sjaltenb on November 13, 2008, 06:26:16 PM
That should work.  Not sure of the actual current draw but I imagine its less than 30mA. Drop a 1 ohm resistor in line with the +12 and measure it.
Ron Neely II
fx schematics and repairs
sjaltenb
wow, i got THE EH man to respond  :icon_mrgreen: Im much more confident now  :icon_lol:
thanks!
But hey...does anything with the grounding change?? It looks like the center tap was linked the ground...so, probably not...but just checking
