Tubescreamer Op Amp?
Started by jlaugh87, November 21, 2008, 03:36:15 PM
jlaugh87
Ok so when I started building clones, one of my first was the ts 808 clone on general guitar gadgets.  I built this a while back, and now the Op Amp seems to keep blowing.  In the past month I have replaced 3, and I'm not sure what could cause this.  I have double checked to make sure my power supple is 9 V, but I have no idea after there.
Any insight would be much appreciated.
John
PLEASE borrow a meter from someone and measure the voltage at pin 8 of the chip.
jlaugh87
Which pin on the chip should be ground? I cant find any info about the pins on the net?
The chassis will be ground, and so will the nut that attaches the pot to the chassis.
MusicAudio
Quote from: jlaugh87 on November 21, 2008, 04:11:26 PM
Try searching google for "dual op amp". Below is a link to a picture of the pinout for a dual op amp.
http://www.analog.com/static/imported-files/images/Product_Descriptions/374874868AD827_fbl_01.gif
I don't care much about music. What I like is sounds.
-Dizzy Gillespie
Electron Tornado
Here's a link or two where you can search for semiconductor data sheets. Data sheets will show you the pins.
http://www.alldatasheet.com/
http://www.datasheetcatalog.com/
http://www.datasheetlocator.com/
http://www.datasheetarchive.com/
"Corn meal, gun powder, ham hocks, and guitar strings"
Who is John Galt?
