IC names
Started by bassmasta17, November 24, 2008, 08:43:28 PM
bassmasta17
from my studies here i have found many diffrent names here. if any one knows what the difference is post away.
i play bass.
www.freekbass.com
earthtonesaudio
Names vary depending on the manufacturer.  For example Texas instruments might make a LM380 while the NTE replacement part is 740A.
But for the most part, ICs are named similarly to the first one of that type.  The "741" single op-amp was very popular, and is made by many companies.  Most of them use 741 in the name even though they're not the original manufacturer.
Same for the 4558 dual op-amp.
But in general the name of the IC doesn't tell you anything about what's going on inside.  Not like tubes where the numbers actually describe the number of pins or something.  If you want to know what the names/numbers mean, you have to look it up.
bassmasta17
Anything on the tone?
i play bass.
www.freekbass.com
earthtonesaudio
bassmasta17
thanks i thought their might have been a toneage diffrence.
i play bass.
www.freekbass.com
blackcorvo
OF COURSE there's a tonal difference from different op-amps, but that's not noted in their codes.
but if you check their datasheets you'll see they have different frequencies range. some work from AF to RF.
this frequency range is, IMO, what defines their tonal characteristics.
She/They as of August 2021
jacobyjd
phaeton
Stark Raving Mad Scientist
Cjuried
As a rule of thumb, always refer to the manufacture(s) data sheet(s) and compare specifications between multiple manufactures.
Chris Juried
Audio Engineering Society (AES) Member
http://www.juriedengineering.com (Juried Engineering, LLC.)
http://www.tubeequipment.com (Tube Equipment Corporation)
http://www.historyofrecording.com (History of Recording)
" I will say no more "
Jdansti
Quote from: Jdansti on May 12, 2016, 03:00:21 PM
Someone's been playing with flux capacitors.
Yeah, but whose flux capacitors?  Manufacturer makes all the difference...   ;)
RickyTerzis
Hi...i am a new user here. As per my knowledge Cs are named similarly to the first one of that type.  The "741" single op-amp was very popular, and is made by many companies.  Most of them use 741 in the name even though they're not the original manufacturer.Same for the 4558 dual op-amp.
Hatredman
Quote from: Cjuried on May 12, 2016, 10:40:43 AM
As a rule oficial thumb, You shouls always Necropost.
Enviado de meu MotoE2(4G-LTE) usando Tapatalk
Kirk Hammet invented the Burst Box.
