Runoffgroove Eighteen technical question
Started by Axe_34, November 26, 2008, 09:55:06 AM
Axe_34
Hi everyone.
I've just started to populate a perfboard using the info at http://www.runoffgroove.com/eighteen.html.
However, I'm confused about one thing -- the parts list and PCB layout both list a 100uf cap in the circuit at C11. (http://www.runoffgroove.com/18-pcb.pdf)
However, I don't see it on either the schematic or the perfboard layout diagram. To make things a little more confusing, I think I see it in the actual photo of the assembled board between the first and second trim pots.
Can anyone clear this up for me?
Thanks in advance for your help.
B Tremblay
Correct, the 100uF cap is missing from the schematic and perf layout.  Gary added one in for his perf build, but I must have missed it while making the layout.
B Tremblay
runoffgroove.com
Axe_34
Thanks for the quick reply. (And to my e-mail too!  :) )
Can someone double-check this for me? I think this is where the cap would go -- from the pin on the third trim pot to ground.
Axe_34
Hmmm. Now that I look at it again, I think it's supposed to come of the pin on the furthest left trim pot.
B Tremblay
It doesn't matter where you physically place it on the board, as long as the positive lead connects to the positive power rail and the negative lead to ground.
B Tremblay
runoffgroove.com
Axe_34
