Optochopto: A wah based tremolo
Started by dano12, December 08, 2008, 07:50:45 PM
DWBH
Can I use a CD4093 if I tie the 2 inputs together on each trigger?
oskar
Entrant_21
Quote from: Barcode80 on January 03, 2009, 12:55:05 PM
Quote from: Entrant_21 on January 03, 2009, 10:58:09 AM
Quote from: Barcode80 on January 02, 2009, 07:15:56 PM
Just an FYI, i built the boost portion of the circuit (on a new cleaner layout, if there is interest i will post it), and though the tone is nice and does add a certain character, it doesn't offer a lot of gain boost. If I could figure out how to goose it a little for more noticeable boost, it would really be a nice booster. any ideas?
Try reducing the 6.2M fb resistor to like 2M or something.. I think that'll work.
yeah, tried that, no dice. I wonder if just cascading it into a mosfet booster would retain the same tonal characteristics jus twith more volume.
try increasing the 10k resistor at the collector that should increase it..again i think. I'm fairly new to transistors, i mainly use op-amps etc.
DWBH
#23
I just breadboarded this (used a CD4093). Glamorous video is on its way!
However, I didn't hook up the LED as is on the schematic. That way it wouldn't blink.
I hooked it up between the input and the output of the trigger - SUCCESS. It blinks now. I missed something.
Either way it's so cool. Wha + Tremolo = holy cow!
Here it is: http://www.vimeo.com/2709959
DWBH
#24
I can see why it's called Optochopto. The LFO generates a square wave, giving that chopped sound.
Maybe another (more complex, although) LFO could be implemented, like the one on a tremolo (the Tremulus Lune, for example).
There's another way of hooking the CD4093 up. Instead of tying (?) up the 2 inputs, one goes to +9v, and I've got one trigger just like the one on the 40106. Like this:
Can we get a sinewave, or a less square-y wave out of an oscillator of this kind?
Also, I'd suggest a 100k resistor in paralell with the resistor side of the vactrol (this is if its resistance is 10meg, like in most cases).
dano12
Quote from: DWBH on January 05, 2009, 01:14:47 PM
first off, thanks very much for the clip--I would have probably never got around to it.
Yes, a triangle/sine LFO would be interesting, and certainly make it more versatile. I would imagine any LFO capable of driving the Vactrol would work.
DWBH
#26
What clip? That hideous thing?
Just had a crazy idea: 4 wah's in series, each one controlled by an oscillator, with each wah tuned with different resonance and frequency peak. Yuck, it'd probably sound like crap.
dano12
Quote from: DWBH on January 05, 2009, 01:21:47 PM
or add 8 pots and you have a zvex ooh wah
DWBH
#28
Not sure if you were kidding or not, but I always thought the Ooh Wah was just a sequencer changing the pot's resistance of one wah.
I tried the oscillator setup like I said above, but as before, I only get oscillation it I connect the LED to the output and input of the oscillator. Strange.
ADDED LATER: If one uses a square wave oscillator, I'd reccomend the use of a blend/mix control, blending/mixing both dry and wet signals.
With a square wave oscillator you're only going to hear the two extremes of the wah sweep, so you loose (so to speak) a lot.
DWBH
I've found another 'modulated wah':http://www.members.shaw.ca/roma/wah-two.html (scroll down - running wah).
The wave produced is a sine wave, which produces a smoother sound.
The cool thing would be to have all sine waves, triangle waves and square waves in the same circuit - tremolo LFOs!!
jacobyjd
Quote from: DWBH on January 05, 2009, 06:25:06 PM
I was wondering about this--I know dano mentioned that you could use just about any LFO that would drive a vactrol...I immediately thought of some of the more versatile trem LFOs.
I think this circuit just made it to my 'build asap' list.
AM
Hey Dano,
I have a question regarding the schematic. I looked at a layout I had and there are a few different values from yours
(C1-C7- added Vr=100k). Is yours based on the reissue version?
Link to layout:
http://www.aronnelson.com/gallery/main.php/v/Cab42s-layouts/cil_wah.gif.html
DWBH
Quote from: jacobyjd on January 06, 2009, 09:03:27 AM
Hell yeah, it made to my build list as well. Next time I order parts I'll make sure I order parts for this one.
dano12
Quote from: DWBH on January 05, 2009, 01:49:35 PM
Yeah, I was talking about adding 8 pots to control the setting of one wah.
Quote from: AM on January 06, 2009, 09:32:57 AM
Hey Dano,
Link to layout:
I swapped a few values to make it sound a bit better.
In other news, I finally got what puretube quoted about the "worm". The EHX Worm pedal does something similar: an LFO that controls four different circuits: phase, wah, etc. The new XO version looks super hot and it has an exp pedal input so you can bypass the lfo in favor of a foot controller. Genius!
Anyway, I think the ultimate rendition of this idea would be:
- a powerful and versatile LFO: sine, triangle, square, + programmable (maybe like the DSWF I did last year?)
- multiple filter circuits: like the EXH Worm--a wah, a vibrator, a phaser, etc.
That would kick some serious ass.
DWBH
I was trying to fetch the older version of the EHX Worm on Ebay, but the guy won't ship to Portugal :icon_cry:
I'm very interested in the Worm schematic (http://www.diystompboxes.com/smfforum/index.php?topic=55068.msg593841#msg593841), so if anyone has it, please share it! ;)
I wouldn't build a box with various filter circuits. Imagine you wanted different LFO rates/depths/whatever for, say, the vibrato and wah. You'd need different LFOs (crazy!, man!)
I'd rather have them in seperate boxes, but that's just my personal taste. :icon_lol:
oskar
The rate LED? You need a series resistance to go with it or the LED will probably sink too much for the LFO to operate. It won't charge the cap up till switching level.
DWBH
#36
Quote from: oskar on January 06, 2009, 09:59:04 AM
Hummm.. ok, I'll try that.
HOLY SH*T, I just say this article
http://www.beavisaudio.com/Projects/DSWF/
:icon_eek: :icon_eek: :icon_eek:
I knew about the Arduino thing, but I never thought such cool things could be done with it.
kinski
Hi all, thanks for the great info on this circuit!
Is there a verified layout or pcb of this?
It would be great to have the circuit so there is the standard colorsound wah (for fixed wah sounds), and then a switch to engage the LFO circuit.
