Removing Goop From A 1974 Maestro Sustainer SS-3
Started by ilponiz, December 10, 2008, 12:35:39 PM
ilponiz
Hi everyone,
just bought this pedal from e(vil)bay few weeks ago:
it wasn't working and, as i read all over the places, the cicrcuit was well-protected with think black goop:
i looked for info about the removal of that sh*t and i ended up with this:
fortunally, few minor damages were down to the traces so that i will easily redrawn them in the next days. as for the components side, is there any method you'll suggest to remove the goop without damaging too much the rest?
thanks in advance to anyone who'll help me in doing that (i consider this as the first active contribution to this great forum  :icon_biggrin:)
by the way, i guess there's no schematic available for the pedal, isn't it?
have a glorious day
poniz
theehman
The official Maestro schematic showed the wires connecting to a large block.  That's it.
Ron Neely II
fx schematics and repairs
ilponiz
Quote from: theehman on December 10, 2008, 12:38:07 PM
Hi Ron,
thanks for the info and, let me add, thanks for all of your excellent EH designs  :)
so, it's virtually impossible to get info on this pedal, i guess... :icon_rolleyes:
anyway, given that my unit isn't working i'd like to keep on removing the goop and see what's beneth. any suggestions on how to do it?
my regards
poniz
theehman
Quote from: ilponiz on December 10, 2008, 01:05:09 PM
Hi Ron,
Just to clarify, I am not now, nor have I ever been, an EH employee or designer.  Just a fan and collector.
Ron Neely II
ilponiz
Quote from: theehman on December 10, 2008, 01:15:12 PM
Hi Ron,
just to clarify...I'm a jerk!  ;D ;D ;D anyway, from fan and collector to fan and collector: thanks!  ;)
Given how little competition there was in 1974, the odds of it being "gooped" for the purposes of protectng I.P. were very small.  Besides, Maestro did not goop their other boards.  So, my guess is that it  has some light source and LDR in there, and the goop was just a sledgehammer attempt to assure light-tightness.
ilponiz
Quote from: Mark Hammer on December 10, 2008, 03:13:37 PM
hi mark, thanks for the idea you suggested. i assume the maestro sustainer is some kinda compressor or what?
from the traces that came out the goop there are two different ic's in here...the rest is yet to come!
;D
poniz
frank_p
Wonder if the discontinued Guyatone Sustainer D had a similar circuit.  If so it would be a fuzz with long sustain...
ilponiz
Quote from: frank_p on December 10, 2008, 05:48:46 PM
hi frank,
do you have a schematic for the guyatone?
looking at the trace side of the circuit i could spot the following pads used for:
- 2 IC's with 14 lugs each
- a few diodes
- at least 7/8 polarized electros
more to come soon...
and thanks to analogguru!
poniz
Renegadrian
frank_p
#12
Quote from: ilponiz on December 11, 2008, 11:21:11 AM
No, but I would like to, everything is so crammed in the mini box that I can't read most of the values of the components.
- a few diodes
njm4558ld chip (8 leads ...?)
7 electros caps
8 film caps
3 ceramic caps
1 monolithic cubic blue cap
5 transistors
3 pairs of diodes plus one lonely diode, plus one for power protection it seems
all resistors soldered in standing vertical position.
so it might not be similar.
When I bought it I was sure it was a compressor, but it's a fuzz with a lot of sag (it seems from the website).
In no way it sound like an amp as claimed again on the site.
With the gain at minimum and guitar volume at 5, can sound like a descent effect for soloing.  Otherwise it's a wall of noise-distortion generator. Chords don't pass in this, unless it's two notes... at most.
Cramming everything seems to be a good technique, as goop is, against reverse eng. ...
Yours
F.H.P.
ilponiz
Quote from: frank_p on December 11, 2008, 12:51:49 PM
- a few diodes
7 electros caps
8 film caps
3 ceramic caps
5 transistors
Yours
F.H.P.
hi frank,
i think it's different...at least, there's no trace of a 8-leads chip in the maestro sustianer. as i wrote before, there are 2 different 14-pins IC's
anyway, thanks for your help
poniz
frank_p
#14
Cool. Still, wonder how the Maestro sounds like...  :)
We now know that theses are two different beasts.
Yours Poniz.
