Peppermill with clipping diodes help.
Started by Jamforthelamb, December 10, 2008, 05:05:30 PM
Jamforthelamb
Hey all,
I recently added a diode clipping stage to my peppermill (leds on one side of the switch, sili on the other). I added it at the end of the circuit before the volume pot. It works well, but only when the pedal volume is turned all the way up (very loud!). Is there a way I can change this so that the clipping still works at a reasonable volume ?
jftl
jacobyjd
is your volume pedal before or after the distortion in your effects chain?
bassmasta17
i think he means in the pedal (the volume pot). I also have the same problem in the fuzz i made but it clipps at low levels also but sounds better at a high volume.
i play bass.
www.freekbass.com
Jamforthelamb
jacobyjd: Volume pedal is the 2nd to the last thing in my chain (delays are on the end for swells).
bassmasta17: That's correct. That's exactly my problem.
jftl
doug deeper
did you put the diodes after the volume pot?
if so youve made a clipping threshold control so to speak.
before the volume pot and you'll have clipping all the time.
Zben3129
try adding the diodes after the .047 but before the 8k2
Zach
Jamforthelamb
Doug: The diodes are just before the volume pot.
Zben3129: Thanks! I'll try that.
jftl
Caferacernoc
"try adding the diodes after the .047 but before the 8k2"
That will work much better. The 8.2k resistor will "seperate" the function of the clipping section and the volume section. Added bonus is that the low pass filter will be after the clipping so it can roll off any fizz.
Jamforthelamb
Zben3129 and Caferacernoc: Thanks! That seemed to do the trick!
-jftl
Caferacernoc
Jamforthelamb
I made some samples so everyone can listen for themselves.
http://www.soundclick.com/bands/default.cfm?bandID=902107
If you click the "full" link there is some text explaining what my settings are.
Thanks again!
-jftl
Caferacernoc
That sounds pretty good. Is that into a miked amp and speaker or straight into a recorder. I'd say if it's not a miked amp the clips sound excellent!
Jamforthelamb
I used the line out on my amp. The amp is a Peavey Duece twin amp set very clean (about the only thing it does well), so the pedal is responsible for any distortion. I need to get a mic stand for my sm57 then I hope to put some mic'd recordings on that same page.
-jftl
Caferacernoc
Yeah, then that sounds real good. I hear a bit of frazzle on the top end when you really dig in, but that would go away when played through a real guitar speaker which has almost no output above 5000hz.
Good juicy and dynamic sounds from that pedal.
Good job.
oskar
Buddy!
Even though moving the diods took care of the problem... they should really have worked fine in the original position.
You're volume pot is probably hooked up the wrong way.
It sounds to me like you feed the middle lug and route the other lugs to out and ground respective.
That would totally explain the behavior.
oskar
Jamforthelamb
Well, for whatever the reason changing it fixed it. In fact I think it sounds better now!  :icon_biggrin:
-jftl
Zben3129
Quote from: oskar on December 19, 2008, 02:02:06 AM
Buddy!
oskar
If the diodes are placed after the 8k2, the volume pot acts as a parallel resistance to the diodes. With the pot on 10, the resistance parallel to the diodes is at its maximum, so more current can flow through the diodes. As you turn the volume down, the resistance to ground decreases, allowing the resistor to carry more current and the diodes less. Consider the volume pot on 0, the diodes are shorted to ground, so no clipping whatsoever. The way you originally had it wired is essentially a gain control, not volume control. This is why it wouldn't work.
Zach
oskar
