Old Electrolytic Capacitors?
Started by davent, December 17, 2008, 08:21:38 PM
Hello,
I've got some small value electrolytic capacitors here (1uF, 2.2uF, 3.3uF) that are at least 20 years old and never been used. Would these still be good, is there any way to test them to see if they're still OK or should I just scrape a few pennies together and replace them?
Thanks for the help!
dave
Pedal love
kurtlives
I would think smaller caps (voltage rating) would last longer than the filter caps in our amps that we are supposed to replace very  5 - 10 years. There is less electrolytic liquid and it would seem it would be harder for it to dry.
My DIY site:
www.pdfelectronics.com
Hi guys,
These are all just little ones I want to use in pedals, 50v and 63v, (although if they're any good they could be pressed into service as cathode bypass caps on preamp tubes.)
dave
frank_p
You have to measure the ESR (serie resistance that builds in the electrolytic):
There are some charts pointed by RG:
http://www.diystompboxes.com/smfforum/index.php?topic=72006.msg581498#msg581498
Also:
http://www.diystompboxes.com/smfforum/index.php?topic=65451.0
Also, search for ESR on the net, you should find some more info.
Yours
bassmasta17
i dont know anything about this but their are amps out their older that 20 that still work. They should work. just don't do this from what i said! ;D
i play bass.
www.freekbass.com
Electro caps decay from sitting on the shelf. They decay in use, too. If held with a voltage on them and cool, they decay slowest. If hot, they decay faster.
Old, but unused caps may be OK, but I personally would only use them for temporary tinkering, not where I'd have to go troubleshoot a failure in a few weeks/months. Test them before using them.
Quote from: R.G. on December 18, 2008, 06:31:44 PM
Thanks R.G. that's what I needed to hear.  Would be pretty foolish to use an old cap to save a dime then have to spend considerable time and energy troubleshooting later.
Quote from: frank_p on December 17, 2008, 10:44:17 PM
Also:
Yours
Thanks Frank, found a post in one of links you posted where R.G. describes some methods to test caps without having to spring for some new toys :)
Take care
dave
