Help...Nyquist Aliaser with Envelope mod doesn't work!
Started by gigimarga, December 21, 2008, 01:16:35 PM
gigimarga
I've just finished a Nyquist Aliaser with Envelope Follower mod using this schematic: http://www.moosapotamus.net/IDEAS/nyquist/NyquistENV2.gif and this PCB: http://www.diystompboxes.com/smfforum/index.php?topic=72366.0.
I used BC549C instead of 2N5210 and i don't wired the CV input (i see no use for it right now).
All the FETs are 2N5457.
The clean signal pass through the effect with no mod, maybe it's a little compressed (but i'm not sure).
I cut the wire betwwen the Sensitivity pot and C4 to disconnect the Envelope Follower and no change.
"oldrocker" made some suggestions to me, but i have no 2N5952 to try...only some J201 and 2N3819.
I've looked on the JC Maillet's site, but the informations founded didn't help me.
I've read some posts, but it's clear that it's a sensitive build.
So, can anybody to indicate me some target voltages?
For exemple, it's ok to assume that i must to obtain 0V on Q5's base using VR2?
Thx a lot all!!
gigimarga
I replaced first JFET with J201 and no change.
What could be the voltage on Q1's drain?
moosapotamus
Is that a verified layout... has anyone else ever used it to build a working unit?
Thats' the first thing I would do... trace the scheme and layout side-by-side and convince your self that they are exactly the same.
~ Charlie
moosapotamus.net
gigimarga
Quote from: moosapotamus on December 22, 2008, 04:26:18 PM
~ Charlie
Thx for your advice Charlie!
Anyway, can you post some voltages from your unit?
moosapotamus
Actually, I breadboarded the whole thing to work out the envelope mod, and never built up a permanent one. Something else is living on my breadboard now, so I can't get any voltages for you. Sorry
~ Charlie
moosapotamus.net
ballooneater
#6
I think I may have found the source of your problems.  In my layout (the one in the first post), pins 2 and 3 of IC2 should be flipped around.  I had R16 (on my layout) connected to the inverting input and C5, R15, and D2 connected to the non-inverting one.
So sorry for the inconvenience!
gigimarga
Quote from: ballooneater on December 22, 2008, 10:18:32 PM
Thx a lot again ballooneater!!!
I think it's a problem for the envelope section, but mine doesn't work with this section disconnected, as a simple nyquist aliaser :(
gigimarga
I rechecked the PCB and it seems to be OK.
Any clues about the voltages?
oskar
Quote from: gigimarga on December 21, 2008, 01:16:35 PM
No. If someone wanted 0V on that pin they would probably just have grounded it.
Quote from: gigimarga on December 24, 2008, 04:48:25 AM
Actually, I think you are the one who should provide voltages. You have an envelope, a VCO, a S/H and whatelse.
Test one part of the circuit at a time. VCO... clock? ( use audioprobe ). Envelope out? ( U2b ( If you first reconnect it ))
gigimarga
aloupos
I've been wanting to build this ... I'll throw a pcb together and see if I see the same results.
gigimarga
I want to test it by modules, so which is the VCO and which is the S/H?
oskar
Quote from: gigimarga on December 27, 2008, 01:13:29 PM
VCO    U1A and the parts surronding...
S/H     Q2, Q3, Q4
