Need Help With FL301 Build / Debug
Started by Zben3129, January 01, 2009, 04:19:09 PM
Zben3129
Happy 2009 everyone,
Tried to build the FL301 from tonepad, and it isn't working. When engaged I get a weak, clean signal through, accompanied by loud! hum. When I take out the mn3007, the hum gets quieter, but is still present. Also, the regulator (A TO-220 package, 1A) is heating up. Not too hot that I can't touch it, but it is generating heat. I can't see any glaring issues with the Voltages:
IC101:
1 - 6v
2 - 6
3 - 4.1
4 - 0
5 - 6
6 - 6
7 - 6
8 - 11.8
IC102
1 - 6v
2 - 6
3 - 6
4 - 0
5 - 6
6 - 6
7 - 6
8 - 11.8
IC105
1 - Var between 2 and 8v
2 - 5.3
3 - Var between 5 and 6.3v
4 - 0
5 - 5.8
6 - 5.8
7 - Var between 5 and 6v
8 - 11.8v
MN3007
1 - 11.8v
2 - 6
3 - 1.07
4 - 0.8
5 - 0
6 - 6
7 - 3.1
8 - 3.1
MN3101
1 - 11.8v
2 - 6
3 - 0
4 - 6
5 - 9.5
6 - 2.3
7 -7.9
8 - 0.8
Also, is Q106 definitely PNP? Looks like NPN on the schematic.
Is Q107b definitely NPN? Looks like PNP on the schematic.
Subbed 4558s for all the tl022s
Zach
PerroGrande
Q107 looks to me like an NPN for certain.  The emitters are grounded and the collectors run off to the positive supply.
Q106 is a bit odd.  The schematic drawing *does* look like an NPN, but everything about the way it is connected says PNP... Emitter tied to the positive supply, etc...  yeah -- looks like a PNP in spite of the drawing.
Zben3129
Thats what I figured, they didn't seem like they would function the way the schematic seems to show them. I wish there was a good version of that somewhere, without the switching junk  :icon_eek:
Zach
Zben3129
Hmm... with my meter set to continuity, it shows continuity with a reading of "1322" (ohms?) and beeps, but once I apply power it stops beeping and shows the symbol for no continuity. I have a feeling this points to something specific, perhaps a cap?
Zach
Andre
Q106 is a PNP for sure. The schematic says Q106 is a 2SA1015 which is a PNP transistor.
This goes for all japanese transistors:
2SAxxxx and 2SBxxxx are always PNP
2SCxxxx and 2SDxxxx are always NPN
André
