New Amplifier Design - "Murder One" - Submini Pentode, Low Voltage
Started by frequencycentral, January 05, 2009, 03:32:11 PM
TNblueshawk
Hey C3. I just happened to click into this. Rather than go off my memory exactly let me get home and look at my wiring. I did use a CLR in series with the LED for sure. Trying to remember the rest though. It was a DPDT of course and I just wired middle and end lugs leaving one end empty.
I'll post up tonight.
TNblueshawk
Hey C3 here is the deal.
DPDT
Top row of lugs
Left lug: wire to 12v pad on PCB
Right lug: CLR/LED pos leg of LED
Middle row of lugs
Left lug: Just jumper to the right lug
Right lug: run wire to 9v on DC jack
Bottom row of lugs: leave both empty.
One thing however. I think I put this in this thread, and not the one at Circuitworkshop. The only problem I have with my build is I get an intermittent signal. So I'll be playing and then the signal goes out...then it come back...then it goes out etc... I tried some quick troublshooting but can't find that issue. Whether or not it is tied into me wiring this DPDT wrong I don't know as I think it is correct. But, just an fyi.
tom42107
Hello group. Just wanted to say hey and post a pic of my nearly completed "Murder One" amp. Here it is right before I put in the tubes. (Not sure about those knobs yet :)).
I'll post after I fire it up. Thanks (Frequency Central), for such a cool little amp.
TNblueshawk
That thing is so cute I could hug it   :icon_lol:
I love the knobs actually.
Any gut shots?
tom42107
Here's a few more picts. Not the prettiest inside but if I ever make another I'll know just what to do. Gonna fire it up this weekend, (just slammed at work).
tom42107
TNblueshawk
Specifically Hermitage, about a 15 minute drive east from Nashville.
tom42107
I'm in Knoxville. The reason I ask is because I was thinking of starting a DIY audio club. I think it would be a great way to learn more about all this stuff we love to build.
Tom
Maik
On V7-how can I use both signals. My idea is: preamp to my Line6 X3L for fx and the signal from the transformer to a speaker. Cheap 3-way amping  ;D
Quote from: Maik on August 25, 2012, 06:49:17 AM
Take a pre out from one of the lugs of the volume pot, lug 2 if you want the volume to attenuate the pre out, or lug 3 if you don't.
Maik
gretsch61
Hi,
HELP NEEDED!  ;D
I was wondering what kind of Indicatorlight (LED???) is used and where it would be connected.
cheers,
gretsch61
Power/LED:
12V from DC socket >>> SPDT lug 2
SPDT lug 3 >>> LED (via 1K resistor) and PCB
gretsch61
Thx for your quick reply, Rick!
What is the the actual size of the PCB and the enclosure now with Version 7?
cheers & greetz from germany!
steve
gretsch61
Quote from: frequencycentral on August 26, 2012, 11:18:05 AM
Power/LED:
...where should I connect the LED on the PCB?
Maik
Hey Steve
einfach auf 12V+, wie bei jeder Stompbox.
edit ok, ignorieren. Wenn´s Rick sagt...
Quote from: gretsch61 on August 26, 2012, 12:14:42 PM
Nowhere.
Connect LED anode to SPDT lug 3 (via 1K resistor), connect LED cathode to DC socket ground.
Connect PCB +ve input to SPDT lug 3, connect PCB ground to DC socket ground.
gretsch61
Quote from: frequencycentral on August 26, 2012, 12:58:00 PM
Nowhere.
Hi Rick,
is there a SPDT that you would recommend for this? Also, what kind of Switch do you use for the S1 in the switched preamp mode?
Would it be something like this:
Would you be able to point out, where the "+ pin" of the Caps would go on the PCB Layout?
The CAPS: C2, C4, C6, C8, C10, C12, C15, C16 and C19 the "- pin" will connect to the "GND"
But how about CAPS: C1, C3, C5, C7, C9, C11, C13 and C14?  Where does the "+ pin" connect to?
Maybe there is a schematic for your Murder One V7
many thx and cheers,
Steve
U-P-D-A-T-E:
Ok, I have figured out the polarity of Caps C1 to C12 and C15,C16,C19
The only ones missing are the 0.1uF Caps do they need to be soldered
with a special polarity or is the polarity of these Caps of no importance?
gretsch61
Hi Everyone,
I was wondering wether it would be possible to change the two tubes (5672 Submini Pentode and 6111 Dual Triode) for some tubes that would use a "normal" tube-socket. If so, which ones would I be able to use (without loosing functionality)?
I have found something like this for the 5672 Pentode http://www.conrad.de/ce/de/product/157385/Roehre-Elektronenroehre-5672-DL-652-Pole-5-Sockel-Subminiatur-Beschreibung-Subminiatur-Pentode
Would there be something like this for the 6111 Dual Triode too?
cheers & thx,
gretsch61
