lm 380 kits
Started by sickbend, January 05, 2009, 03:35:01 PM
sickbend
my lm380 kit came in and i must say this company does me right every time  paid 11.45 for all this took 7 days to deliver but i cant complain http://www.vakits.com/index.php?cPath=43_60
IC, DIP-8 LM380, 2.5 Watt Audio Power Amplifier 2 ea
Transistor, TO-92 2N3904, NPN, General Purpose 2 ea
Transistor, TO-92 2N3906, PNP, General Purpose 2 ea
IC Socket 8 pin, Low-Profile, Solder Tab 2 ea
PCB NightFire, 162 Hole, .062" Thick, FR-4 1 ea
Resistor 24 Ohms, 1/4 Watt, 5%, Carbon Film  5 ea
Resistor 30 Ohms, 1/4 Watt, 5%, Carbon Film  5 ea
Resistor 47 Ohms, 1/4 Watt, 5%, Carbon Film  5 ea
Resistor 120 Ohms, 1/4 Watt, 5%, Carbon Film  5 ea
Resistor 200 Ohms, 1/4 Watt, 5%, Carbon Film  5 ea
Resistor 390 Ohms, 1/4 Watt, 5%, Carbon Film  5 ea
Resistor 470 Ohms, 1/4 Watt, 5%, Carbon Film  5 ea
Resistor 820 Ohms, 1/4 Watt, 5%, Carbon Film  5 ea
Resistor 1.2K, 1/4 Watt, 5%, Carbon Film  5 ea
Resistor 12.1K, 1/4 Watt, 1%, Carbon Film  5 ea
Resistor 13.3K, 1/4 Watt, 1%, Carbon Film  5 ea
Resistor 15K, 1/4 Watt, 5%, Carbon Film  5 ea
Resistor 20K, 1/4 Watt, 5%, Carbon Film 5 ea
Resistor 36K, 1/4 Watt, 5%, Carbon Film  5 ea
Resistor 82K, 1/2 Watt, 5%, Carbon Film 5 ea
Resistor 124K, 1/4 Watt, 1%, Carbon Film  5 ea
Resistor 200K, 1/4 Watt, 5%, Carbon Film  5 ea
Resistor 240K, 1/4 Watt, 5%, Carbon Film 5 ea
Resistor 330K, 1/4 Watt, 5%, Carbon Film 5 ea
Resistor 510K, 1/2 Watt, 5%, Carbon Film 5 ea
Resistor 620K, 1/2 Watt, 5%, Carbon Film  5 ea
Resistor 820K, 1/4 Watt, 5%, Carbon Film 5 ea
Resistor 1.2M, 1/4 Watt, 5%, Carbon Film  5 ea
Resistor 2.7M, 1/4 Watt, 5%, Carbon Film  5 ea
Resistor 4.7M, 1/4 Watt, 5%, Carbon Film 5 ea
Capacitor 7.0pF, 50v, NPO, Ceramic Disc 4 ea
Capacitor 39pF, 50v, NPO, Ceramic Disc 4 ea
Capacitor 100pF, 50v, NPO, Ceramic Disc 4 ea
Capacitor 220pF, 50v, NPO, Ceramic Disc 4 ea
Capacitor 330pF, 50v, NPO, Ceramic Disc 4 ea
Capacitor 680pF, 50v, NPO, Ceramic Disc 4 ea
Capacitor 1000pF, 50v, NPO, Ceramic Disc 4 ea
Capacitor 5000pF, 50v, X5F, Ceramic Disc 4 ea
Capacitor .01uF, 50v, X7R, Ceramic Disc 4 ea
Capacitor .022uF, 50v, X7R, Ceramic Disc 4 ea
Capacitor 3.3uF, 63v, 85° C, Aluminum, Axial 2 ea
Capacitor 22uF, 100v, 85° C, Aluminum, Axial 2 ea
Capacitor 220uF, 16v, 85° C, Aluminum, Axial 2 ea
Capacitor 470uF, 25v, 85° C, Aluminum, Axial 2 ea
Capacitor 0.47uF, 25v, 85° C, Aluminum, Radial 2 ea
Capacitor 2.2uF, 100v, 85° C, Aluminum, Radial 2 ea
Capacitor 4.7uF, 50v, 85° C, Aluminum, Radial 2 ea
Capacitor 12uF, 63v, 105° C, Aluminum, Radial 2 ea
Capacitor 47uF, 25v, 85° C, Aluminum, Radial 2 ea
Capacitor 100uF, 16v, 85° C, Aluminum, Radial 2 ea
Capacitor 220uF, 16v, 85° C, Aluminum, Radial 2 ea
Capacitor 330uF, 10v, 85° C, Aluminum, Radial 2 ea
Capacitor 470uF, 16v, 85° C, Aluminum, Radial 2 ea
Diode 1N4001, 100V, 1 Amp, Silicon, Power 5 ea
Diode 1N4148, Silicon, Signal 10 ea
LED Dual, Red & Green, Diffused, Rectangular 2 ea
LED Red, Diffused, Round, T 1/3/4 3 ea
LED Green, Diffused, Round, T 1/3/4 3 ea
LED Amber, Diffused, Round, T 1/3/4 3 ea
Potentiometer 1K, Single-Turn, PCB Mount 1 ea
Potentiometer 2K, Single-Turn, PCB Mount 1 ea
Potentiometer 5K, Single-Turn, PCB Mount 1 ea
Potentiometer 10K, Single-Turn, PCB Mount 1 ea
Potentiometer 20K, Single-Turn, PCB Mount 1 ea
Potentiometer 50K, Single-Turn, PCB Mount 2 ea
Phono Jack RCA Phono Jack, Female, PCB Mount 2 ea
Microphone Electret, Panasonic WY-64MNT315 2 ea
Battery Clip 9V, Snap-Type, 2 Wires, 4" Leads 1 ea
Speaker 8-Ohms, 0.1 Watt, Round, Miniature 2 ea
Header Male, 8-pin .100" Centers, Square Post, Breakable 1 ea
Header Female, 8-pin .100" Centers, Square Post, Breakable 1 ea
Switch Pushbutton, SPST Momentary, PCB Mount 2 ea
now my turn to make my own 2 watt plexi  :P or 2 watt tube cricket
sickbend
so far I'm pretty pleased the lm380n-8 is only .7 watts but it seems to be able to handle pedals better then the ruby it might be cause there is no buffer yet I will add a fetzer in front and see how it behaves so far it's a great dirty amp though at 12 volts it stays cool enough I don't think it will need a heat sink more mad science experiments to do    :icon_wink:
runmikeyrun
I think i have one of those in my basement, would you mind sharing the schematic and layout if you have one?
Bassist for Foul Spirits
Instagram: @torcheffects
Dislikes: old women
sickbend
I will when I have something solid I'll send you the simple power amp section though
http://www.rason.org/Projects/icamps/icamps.htm
I think im going to make the runoffgroove 18 or use my distortion plus as a preamp dirty channel just trying to think how to switch the inputs and if i want to add a tone stack or not if i want it foot switchable etc lots to play with but im enjoying myself and im getting killer tone
