Where i can find Crazy Larry and Analog Bit Crusher PCBs?
Started by gigimarga, January 19, 2009, 02:48:36 AM
gigimarga
Hello,
Now, I'm fallen in love with aliasers. I've built two Nyquist Aliaser (classic and with CMOS) and i want to test more.
The only ones that i found was Crazy Larry (where i can find samples with it?) and Analog Bit Crusher (with a wrong PCB in Choklitloves gallery).
So, where i can find some PCB for them?
Thx a LOT!
The Tone God
I'll rehost the samples later. I don't think there is a board for Crazy Larry.
Andrew
The Tone God
gigimarga
Thx a lot Andrew!
It sounds amazing...i hope i will find a PCB :)
Cliff Schecht
#7
Do you have a schematic? I can draw up a PCB for it..
Edit: Found it. Cool idea, sounds like a weird heterodyner or something.
Andrew, you draw your jfets like I draw my mosfets :P.
gigimarga
Quote from: Cliff Schecht on January 21, 2009, 04:48:52 AM
Thx a lot Cliff!
The Tone God
I was using new software and was in a hurry to get it done for entry. I couldn't find the FET part in the library but I could find the MOSFET so I used that and made sure to put the part number.
Andrew
Cliff Schecht
Quote from: gigimarga on January 21, 2009, 07:33:19 AM
Thx a lot Cliff!
I'm going to size the board for a 1590BB type enclosure because it's a headache trying to fit so many pots into anything smaller. Are you planning on etching this yourself?
gigimarga
Thx a lot Cliff...the size of the PCB doesn't matter for me because i have some big enclosures, non-standard.
Cliff Schecht
#12
So I finally got a PCB worked out with, as of now, only one jumper. I should be able to eliminate the jumper after I tweak the layout. It took me a while to rough out this board because with 8 op amps and a single-sided PCB, you have to be very meticulous about how you layout the op amp pins. I was hating Andrew by the time my second attempt at laying this board out failed, but it's finally right!
Edit: Nevermind on the jumper, I got around that too.
The Tone God
Quote from: Cliff Schecht on January 25, 2009, 04:59:25 AM
Hug ?
Andrew
Cliff Schecht
Real men hug. Thanks :P.
I'm too lazy to align the pots along the edge, unless somebody wants to pay me money to work on the layout some more :). I'll probably have this board posted up Monday or Tuesday.
gigimarga
Thx a lot Cliff!
Can you post it today, please?
My PCB are made by a friend from another town and he will send me others in 2-3 days, so i want very much to make this layout quickly.
Processaurus
gigimarga
Quote from: Processaurus on January 26, 2009, 08:44:34 PM
Quote from: gigimarga on January 26, 2009, 08:31:30 AM
Would you like fries with that?
Sorry for my English, but i don't understand what are the fries for here  :-[
Cliff Schecht
It was a joke :P.
I finished the layout and will get it posted tomorrow.
gigimarga
Thx a lot Cliff!!!
You're wonderful!
I think that i understood the joke...my big problem in English are the expressions (and the joke, as i saw) :(
