Series and Parallel Mixing options
Started by sjaltenb, January 30, 2009, 05:37:57 PM
sjaltenb
Hello all,
OK so this might seem like a roundabout way of doing things, but it is the only way I can come up unless someone already has this design:
I want to be able to add a certain Effect in Series or Mixed in Parallel. This is how I was planning on doing it:
Signal - Splitter   1) To Effect
                         2) To Parallel Mixer input 1, no volume pot
From Effect, Signal is split again  1)To mixer input  w/ volume pot for mix amount
                                                2) To SPDT Switch
the Switch selects between: The effect's output signal (series), or the Mixer's output signal (parallel)
Am I making this too complicated?
grapefruit
That seems like a reasonable way to do it, or you could put the volume control on the dry signal, take the output from the mixer out and just switch the dry signal on and off....
Stew.
