Anyone have a pdf link for 16mm alpha pots?
Started by John Lyons, January 31, 2009, 01:09:21 AM
John Lyons
Anyone have a link for a pdf for a 16mm Alpha pot?
I couldn't find a pdf over at Alpha's site.
I'm looking for something that I can cut and paste to lay out
a drilling pattern and get the spacings correct in the box.
thanks
john
Basic Audio Pedals
www.basicaudio.net/
zyxwyvu
I found this at mouser:
http://www.mouser.com/catalog/specsheets/XC-600177.pdf
For some reason, the datasheet says xicon, even though it's an alpha part.
John Lyons
Basic Audio Pedals
www.basicaudio.net/
Captainobvious99
John, I was searching for the same thing recently. These may also be helpful...
(These are Pushtone's drawings, not mine btw)
http://www3.telus.net/david65/pedal-pics/drill-template/
arma61
May be late, anyway this is the link to the alpha pots, not a pdf though !
http://www.alphapotentiometers.net/html/16mm_pot_2.html
Cheers
Armando
"it's a matter of objectives. If you don't know where you want to go, any direction is about as good as any other." R.G. Keen
John Lyons
Thanks fellas.
Between the renderings and the images at Alpha I should be set.
john
Basic Audio Pedals
www.basicaudio.net/
