Difference between a Timmy and Barber LTD Silver?
Started by gutsofgold, February 05, 2009, 02:03:26 AM
gutsofgold
Currently debating on which to build/buy for a new low gainer... I actually can't see them sounding too far off from each other.
Ben N
Definitely similar. The Zendrive isn't that far off, either. Obviously the eq is different, and the clipping, but it does seem they both aim for similar tonal territory.
kurtlives
Breadboard!
That being said I like the "Jimmyy" better. Is is more clear and dare I say transparent than my "Zumodrive". The Zumo is very rich and clear but I like the Jimmy more...
My DIY site:
www.pdfelectronics.com
Captainobvious99
Quote from: kurtlives on February 05, 2009, 01:09:10 PM
Breadboard!
Do you have a schematic/layout for the "jimmy" ?
jimbob
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
phintze
From what I understand, the Dano transparent overdrive is a Timmy Clone... I'll save my $39 and hang on to the real deal.
Ben N
It's a simple enough circuit that laying it out on a breadboard, a piece of perf or a RS-type prototyping board should be easy enough without a layout--just follow the schematic. As it happens, PaulC doesn't use pcbs--he makes Timmys and Tims on proto-board. There are gut shots to be had out there, so I guess that could serve as your layout, if you really want one.
phintze
kurtlives
Quote from: phintze on February 06, 2009, 10:03:05 PM
Actually, the newer Timmys are on PCBs.
Proof?
Paul C has said he is not using PCBs and dosent plan on using them.
My DIY site:
Ben N
Maybe he means the newer Timmys--you know, the ones sold by Danelectro.
phintze
Quote from: kurtlives on February 06, 2009, 10:10:07 PM
Proof?
I haven't taken a picture, but mine (I got it from Paul C in November) is on a PCB.
kurtlives
Quote from: phintze on February 17, 2009, 02:00:01 PM
Proof?
Can you post some pics of this?
My DIY site:
Ben N
Thanks, that's interesting. The layout of the components appears at a quick glance to be identical to the prototype board version. Any chance we could get a look at the other side of the board?
phintze
Well, the other side is stuck down and the wiring is pretty tight. I don't really want to mess with it, since I use this pedal all the time.
Ben N
teletroy
PaulC
Quote from: Ben N on February 18, 2009, 09:12:51 AM
I've been making the pedals with pcbs for about 4 months or so.  I'd rather people not post my layouts so others can copy that.  The circuit's already out there (thanks...), and there's nothing i can do about that.  It's been copied, and sold for less than I'm able to do it, but the pcb artwork is pretty new, and I'd like to move some units before that also gets reproduced.
Regards,
PaulC
tim/timmy pedals
myspace.com/paulcaudio
I like ham, and jam, and spam alot
phintze
Apparently, you can't edit posts on this forum, so I just deleted the pic that I took of Timmy's guts. I'm definitely not trying to intrude on Paul's intellectual property, I just wanted to show that the new Timmys are built on PCBs. Sorry about that, Paul.
