TO-220 case heatsinks?
Started by cpnyc23, February 12, 2009, 08:06:44 PM
cpnyc23
I'm about to put together one of Dano's Subcasters but I don't have a heatsink for the regulator.  Until I get one via the mail, can anyone recommend a way to make one?
Much appreciated.
-chris
"I've traveled the world and never seen a statue of a critic."    -  Leonard Bernstein
earthtonesaudio
I'd suggest looking in a defunct old computer power supply first.  TO-220 heatsinks galore.  Failing that, just hack up a bit of metal to fit in the enclosure without touching anything, drill a hole and bolt it on.  Remember the tab connects to one of the terminals, so don't let it touch anything!
cpnyc23
Or you could use an 18 ohm / 3 watt voltage drop resistor instead of the LM317 - simpler and cheaper - you are running it on 12 volts right?
Or you could use a 7806 instead of the LM317.
Having tried all three methods with 6111 subminis I have to say I prefer to use a 18 ohm / 3 watt voltage drop resistor for simplicity.
cpnyc23
I've considered using a 18 ohm/3W resistor but to get one, I'd have to order it.  I'm just looking for a quick fix.
-chris
